[MPICH] Problem setting up MPICH between a 32 bit INTEL and a 32 bit AMD machine
    Krishna Chaitanya
    kris.c1986 at gmail.com
    Tue Feb 19 11:32:48 CST 2008
Hi Dave,
      Thanks for that. I was pretty much lost over the last couple of
days. Will give it a fresh try again.
      About the AMD machine. I should be able to have access to it in
about 7-8 hours.
Krishna Chaitanya K
On 2/19/08, Dave Goodell <goodell at mcs.anl.gov> wrote:
> responses inline
> On Feb 18, 2008, at 10:35 PM, Krishna Chaitanya wrote:
> > Sorry for the delay.
> > >Can you ping from one to the other
> >           Yes, I was able to ssh into the other machine and try
> > mpdcheck and the rest. Will try to figure out what the problem is.
> Be sure that you actually perform a ping between the two hosts in
> question.  If you ssh'd in from a third host to both of them, then
> you don't have proof of proper routing between the two compute nodes.
> > In the mean-time, I have been trying to understand the progress
> > engine by tracing a standard blocking mode send/recv program, on
> > one machine. ( by using mpdboot -n 1). What exactly are the .i
> > files in the directory /mpid/common/sock/poll for?
> > I noticed that a function like "MPIDU_Sock_post_readv" is at :
> > 1) src/mpid/common/sock/iocp/sock.c, which includes functions like
> > "WSARecv",which is a function to receive data from a socket in
> > windows. ( I am working on a linux platform)
> > 2)/mpich-src/src/mpid/common/sock/poll/sock_post.i.
> >              Interestingly, I am not able to navigate through the
> > macros and functions in this file,by using tags (Why? ) . So, I can
> > only see that we are playing around with pointers to update the
> > pollinfo structure. Where is this structure defined? The .i file
> > does not include any .h file. I tried "grep" on the main dir to
> > locate the definition, it didnt return anything useful.
> >              Can someone point me to a wiki article or any
> > documentation that gives some info on the .i files?
> There are two implementations of the sock code: "iocp" is the Windows
> implementation and "poll" is the unix-style implementation.  Only one
> of the two directories will be used in any particular build.  In your
> case, the "poll" directory will be chosen.
> As for the *.i files, they confused me the first time that I saw
> them.  If you look at src/mpid/common/sock/poll/sock.c:215-222 you'll
> see that they are included via the C preprocessor.  I don't know the
> rationale for this approach as the code was written before I joined
> the project.  It is likely that your ctags program is not indexing
> these *.i files because they don't end in *.h or *.c.  You can
> probably convince it to index the *.i files as well with a
> configuration file or some command-line switches (which will vary
> among various ctags implementations).
> "struct pollinfo" is also defined in that same sock.c file.
> Hope that helps,
> -Dave
> > Thanks,
> > Krishna Chaitanya K
> > On Feb 15, 2008 3:22 PM, Dave Goodell <goodell at mcs.anl.gov> wrote:
> > What evidence do you have that the two machines are able to see each
> > other on the network?  Can you ping from one to the other (and vice
> > versa)?  What is the output of the 'route' command on each of the
> > hosts?
> > -Dave
> > On Feb 14, 2008, at 10:30 PM, Krishna Chaitanya wrote:
> > > Hi,
> > >           Turns out that the settings in the /etc/hosts file on the
> > > AMD machine was incorrect. So, mpdcheck -v -f mpd.hosts gives this :
> > > AMD machine : ( outwit )
> > > kc at outwit:~$ mpdcheck -v -f mpd.hosts
> > > obtaining hostname via gethostname and getfqdn
> > > gethostname gives  outwit
> > > getfqdn gives  outwit.nitk.ac.in
> > > checking out unqualified hostname; make sure is not "localhost",
> > etc.
> > > checking out qualified hostname; make sure is not "localhost", etc.
> > > obtain IP addrs via qualified and unqualified hostnames;  make sure
> > > other than 127.0.0.1
> > > gethostbyname_ex:  ('outwit.nitk.ac.in', ['outwit'],
> > ['172.16.54.54'])
> > ['172.16.54.54'])
> > > checking that IP addrs resolve to same host
> > > now do some gethostbyaddr and gethostbyname_ex for machines in
> > > hosts file
> > > checking gethostbyXXX for unqualified zeus
> > > gethostbyname_ex:  ('zeus', [], ['172.16.54.71'])
> > > checking gethostbyXXX for qualified zeus
> > > INTEL machine ( zeus )
> > > kris.c1986 at zeus ~]$ mpdcheck -v -f mpd.hosts
> > > gethostname gives  zeus
> > > getfqdn gives  zeus.nitk.ac.in
> > etc.
> > > gethostbyname_ex:  ('zeus.nitk.ac.in', ['zeus'], ['172.16.54.71'])
> > > hosts file
> > > checking gethostbyXXX for unqualified outwit
> > > gethostbyname_ex:  ('outwit', [], ['172.16.54.54'])
> > > checking gethostbyXXX for qualified outwit
> > >                Seems to be ok. But I still get this error when I
> > > try mpdcheck -c on the AMD comp :
> > > kc at outwit:~$ mpdcheck -c zeus 33737
> > > Traceback (most recent call last):
> > >   File "/home/kc/mpich-install/bin/mpdcheck", line 103, in <module>
> > >     sock.connect((argv[argidx+1],int(argv[argidx+2])))  # note
> > > double parens
> > >   File "<string>", line 1, in connect
> > > socket.error: (113, 'No route to host')
> > >            The two machines are able to see each other on the
> > > network. Cant exaplain why it complains that there is "No route to
> > > host"
> > > Krishna Chaitanya K
> > > On Thu, Feb 14, 2008 at 2:50 PM, Rajeev Thakur <thakur at mcs.anl.gov>
> > > wrote:
> > > The second test times out perhaps indicates that there might be a
> > > firewall on the AMD machine. See the section A.3 of the
> > > installation guide.
> > > Rajeev
> > > From: Krishna Chaitanya [mailto:kris.c1986 at gmail.com]
> > > Sent: Thursday, February 14, 2008 11:41 AM
> > > To: Rajeev Thakur
> > > Cc: mpich-discuss at mcs.anl.gov
> > > Subject: Re: [MPICH] Problem setting up MPICH between a 32 bit
> > > So, what is the error trying to convey? Googling for it, gave this.
> > > I have flushed the IPtables on both the machines and the firewalls
> > > are de-activated. Could you please elaborate on what kind of
> > > settings I need to look into?
> > > Thanks,
> > > Krishna Chaitanya K
> > > On Thu, Feb 14, 2008 at 10:58 PM, Rajeev Thakur
> > > <thakur at mcs.anl.gov> wrote:
> > > It should be possible. mpdcheck is a tool to diagnose whether the
> > > network configuration settings on the machines are ok or not, and
> > > whether a process on one machine can talk to a process on the
> > > other. It looks like the settings need to be fixed in some way.
> > > Rajeev
> > > From: owner-mpich-discuss at mcs.anl.gov [mailto:owner-mpich-
> > > discuss at mcs.anl.gov] On Behalf Of Krishna Chaitanya
> > > Sent: Thursday, February 14, 2008 10:26 AM
> > > To: mpich-discuss at mcs.anl.gov
> > > Subject: [MPICH] Problem setting up MPICH between a 32 bit INTEL
> > > Hi,
> > >         In one of the previous posts, you had replied back saying
> > > MPICH cannot be put to use between a 32 bit INTEL machine and a 64
> > > bit AMD machine. Is it possible to do so between an INTEL and an
> > > AMD machine, both of them being 32 bit processors?
> > >         Anyway, on trying mpdcheck -f mpd.hosts on the 32 bit AMD,
> > > I am getting the following error :
> > >    ipaddr via uqn (208.67.216.130) does not match via fqn
> > > (208.69.32.130)
> > >         And if I try the mpdcheck -s on the AMD node and mpdcheck -
> > > c on the INTEL node, the client times out. The test message gets
> > > delivered with the client and server swapped.
> > > Thanks,
> > > Krishna Chaitanya K
> > > In the middle of difficulty, lies opportunity
