[mpich-discuss] mpich2 / openmpi conflicts on osx 10.5?
Jeff Squyres jsquyres at cisco.com
Fri Dec 19 09:21:43 CST 2008
I haven't used Xcode, but Eric is right: if you set your PATH and
simply use the wrapper compiler for the MPI that you choose (e.g.,
mpicc), the wrapper compiler should pass the relevant -I and -L flags
to find the "right" headers and libraries.
I do this quite frequently on my OS X Leopard laptop; all I do is set
the PATH (to ensure that I'm using the right MPI executables), and
everything else works out.
On Dec 18, 2008, at 6:21 PM, Eric A. Borisch wrote:
> Thomas,
> You're probably better off using a makefile (which you can have
> XCode run for you for...) so you can just use the mpicc and mpicxx
> wrapper scripts to build. (Note that you'll need to set the path
> environment variable for the make command step within XCode to pick
> up your preferred mpicc.)
>  Eric
> On Thu, Dec 18, 2008 at 11:39 AM, Thomas Blom <blomcode at gmail.com>
> wrote:
> True for execution paths, but I wanted to ensure I wasn't picking up
> the wrong header or libs along the way somehow during builds of
> stuff.  This is easy enough in simple makefiles, but in xcode using
> a native project (which I'm new to) I'm never sure where it is
> looking first etc and so resort to tricks like hiding files.
> Apple's version of gcc and ld also behave differently than
> 'standard' versions of these tools, so hiding or removing all
> headers/libs/binaries for an sdk seems the safest way to me to
> ensure they are not getting involved behind the scenes somehow.
> Again, I'm somewhat new to development on osx.
> -thomas
> On Thu, Dec 18, 2008 at 7:42 AM, Jeff Squyres <jsquyres at cisco.com>
> wrote:
> FWIW, you shouldn't even need to "hide" the default MPI that ships
> with Leopard by putting it in another directory.  If you just set
> your PATH to point to /usr/local/bin before it points to /usr/bin,
> you should be fine (I do this all the time on my MacBook Pro laptop).
> On Dec 17, 2008, at 9:22 PM, Thomas Blom wrote:
> Thanks.  Perhaps that would have worked.  What I ended up doing was
> "hiding" the headers, libs, and exes for the openmpi that came
> installed on the mac.  Then I did the configure, make, and make
> install again, and it worked.
> -thomas
> On Wed, Dec 17, 2008 at 11:12 PM, Rajeev Thakur <thakur at mcs.anl.gov>
> wrote:
> Just try logging out and log back in again.
> Rajeev
> From: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-bounces at mcs.anl.gov
> ] On Behalf Of Thomas Blom
> Sent: Wednesday, December 17, 2008 10:06 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: [mpich-discuss] mpich2 / openmpi conflicts on osx 10.5?
> Hello,
> I've successfully used mpich2 on windows and on a couple of other
> osx machines, but having just built mpich2 from source on a new mac
> pro I encounter difficulty when trying to run some mpi programs.
> OSX 10.5 ships with OpenMPI apparently, such that there are mpi*
> programs in /usr/bin
> I accepted the default when configuring/building/installing mpich2,
> such that it gets installed to /usr/local/bin
> Once I realized that the wrong mpiexec was getting called, I chose
> to "hide" the /usr/bin versions (not knowing otherwise how to
> disable or uninstall the openmpi) by just creating a folder
> _mpi_hidden in /usr/bin and placing all those mpi* programs in there.
> Now when I type "which mpiexec" it correctly states /usr/local/bin/
> mpiexec (the mpich2 installed version)
> But when I try the example "mpiexec -n 3 hostname" I get the error
> message
> -bash: /usr/bin/mpiexec: No such file or directory
> I'm not clear about what's going on here.  Is the python mpiexec in /
> usr/local/bin trying to call the preexisting mpiexec in /usr/bin?
> The original mpiexec in /usr/bin reports this when run without
> argument
> mpiexec (OpenRTE) 1.2.3
> <usage/flags snipped>
> Thanks for any help untangling this problem.  I'm not sure why I
> didn't run into this problem on a new imac that was setup similarly
> a couple months ago...Perhaps OS preinstalled on that system was an
> earlier   rev of 10.5.  For whatever reason it does not have any mpi
> programs in /usr/bin.
> -thomas blom
> ices/ut austin
> Jeff Squyres
> Cisco Systems
> Eric A. Borisch
> eborisch at ieee.org
> Howard Roark laughed.
Jeff Squyres
Cisco Systems
