[mpich-discuss] MPICH2-1.0.8 performance issues	on	Opteron	Cluster
    Sarat Sreepathi
    sarat_s at ncsu.edu
    Tue Dec 16 21:53:13 CST 2008
Sorry, the numbers in the table below are Gflops as reported by HPL.
-Sarat.
Sarat Sreepathi wrote:
> This is a problem with internode communication.
> Each node has 8 cores. So I used the following tests with 4,8 MPI
> tasks. Please note that this is a smaller problem size (N=30000)
> compared to the earlier run.
> HPL  	N = 30000 	N = 30000
>   	sock (Gflops)
> 	nemesis(Gflops)
> 8 on one node 	4.70E+01 	*4.74E+01*
> 4 on one node 	2.60E+01 	2.61E+01
> *8 - 4 x 2 nodes (internode)* 	4.39E+01 	*3.06E+01*
> The case with 8 MPI tasks, 4 per each node (nemesis) is the one which
> has significant 'System CPU' in the image below.
> Thanks,
> Sarat.
> Darius Buntinas wrote:
>> I'd like to see if the problem has to do with internode or intranode
>> communication.
>> Can you try running 10 processes on one node with sock and nemesis?
>> If nemesis is still doing worse, please try 5 processes on one node.
>> Thanks,
>> -d
>> On 12/16/2008 05:50 PM, Sarat Sreepathi wrote:
>>> Hello,
>>> We got a new 10-node Opteron cluster in our research group. Each node
>>> has two quad core Opterons. I installed MPICH2-1.0.8 with Pathscale(3.2)
>>> compilers and three device configurations (nemesis,ssm,sock). I built
>>> and tested using the Linpack(HPL) benchmark with ACML 4.2 BLAS library
>>> for the three different device configurations.
>>> I observed some unexpected results as the 'nemesis' configuration gave
>>> the worst performance. For the same problem parameters, the 'sock'
>>> version was faster and the 'ssm' version hangs. For further analysis, I
>>> obtained screenshots from the Ganglia monitoring tool for the three
>>> different runs. As you can see from the attached screenshots, the
>>> 'nemesis' version is consuming more 'system cpu' according to Ganglia.
>>> The 'ssm' version fares slightly better but it hangs towards the end.
>>> I may be missing something trivial here but can anyone account for this
>>> discrepancy? Isn't 'nemesis' device or 'ssm' device recommended for this
>>> cluster configuration? Your help is greatly appreciated.
>>> Thanks,
>>> Sarat.
>>> _*Details:*_
>>> HPL built with AMD ACML 4.2 blas libraries
>>> HPL Output for a problem size N=60000
>>> *nemesis - 1.653e+02 Gflops
>>> ssm - hangs
>>> sock - 2.029e+02 Gflops*
>>> c2master:~ # mpich2version
>>> MPICH2 Version:         1.0.8
>>> MPICH2 Release date:    Unknown, built on Fri Dec 12 16:31:15 EST 2008
>>> MPICH2 Device:          ch3:nemesis
>>> MPICH2 configure:       --with-device=ch3:nemesis --enable-f77
>>> --enable-f90 --enable-cxx
>>> --prefix=/usr/local/mpich2-1.0.8-pathscale-k8-nemesis
>>> MPICH2 CC:      pathcc -march=opteron -O3
>>> MPICH2 CXX:     pathCC -march=opteron -O3
>>> MPICH2 F77:     pathf90 -march=opteron -O3
>>> MPICH2 F90:     pathf90 -march=opteron -O3
>>> and similar configuration using ch3:ssm and ch3:sock devices.
>>> *> nohup mpiexec  -machinefile ./mf -n 80 ./xhpl < /dev/null &*
>>> *Machine file used:*
>>>> cat mf
>>> c2node2:8
>>> c2node3:8
>>> c2node4:8
>>> c2node5:8
>>> c2node6:8
>>> c2node7:8
>>> c2node8:8
>>> c2node9:8
>>> c2node10:8
>>> c2node11:8
>>> c2master:~ # uname -a
>>> Linux c2master 2.6.22.18-0.2-default #1 SMP 2008-06-09 13:53:20 +0200
>>> x86_64 x86_64 x86_64 GNU/Linux
>>> Processor: Quad-Core AMD Opteron(tm) Processor 2350 - 2 GHz
>>> Sarat Sreepathi
>>> Doctoral Student
>>> Dept. of Computer Science
>>> North Carolina State University
>>> sarat_s at ncsu.edu ~ (919)645-7775
>>> http://www.sarats.com
> Sarat Sreepathi
> Doctoral Student
Sarat Sreepathi
Doctoral Student
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20081216/b2b720ca/attachment.htm>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20081216/b2b720ca/attachment.jpeg>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20081216/b2b720ca/attachment-0001.jpeg>
