[mpich-discuss] Error with more processors
    Rajeev Thakur
    thakur at mcs.anl.gov
    Fri Dec 12 22:19:41 CST 2008
Can you send us a small test program that demonstrates the error?
Rajeev
> -----Original Message-----
> From: mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of yeliu at abo.fi
> Sent: Friday, December 12, 2008 8:00 AM
> To: mpich-discuss at mcs.anl.gov
> Subject: [mpich-discuss] Error with more processors
> Hi,
>    I'm writing an parallel program using MPI.This
> program(with master-slave computation) works well with 3
> processors, but when with
> 4 processors,it has the following error.Does it anyone know
> how to solve it?
>    By the way,I tried to debug it and found only 2 slaves can
> receive the msg of 'no work' when I run it with processors
> <=4 where all the slaves should receive the msg.
> Fatal error in MPI_Recv: Other MPI error, error stack:
> MPI_Recv(186).............................:
> MPI_Recv(buf=0x7fff82e714ec, count=1, MPI_INT, src=0, tag=1,
> MPI_COMM_WORLD, status=0x695ce0) failed
> MPIDI_CH3i_Progress_wait(215).............: an error occurred
> while handling an event returned by MPIDU_Sock_Wait()
> MPIDI_CH3I_Progress_handle_sock_event(420):
> MPIDU_Socki_handle_read(633)..............: connection
> failure (set=0,sock=2,errno=104:Connection reset by
> peer)[cli_3]: aborting job:
> failure (set=0,sock=2,errno=104:Connection reset by peer)
> rank 0 in job 118  maximum.cs.abo.fi_37597   caused collective abort
> of all ranks
>    exit status of rank 0: killed by signal 9
> Thank you very much!
> Ye Liu
