[mpich-discuss] problem of calling .dll in mpich
Vivian
viviantj at gmail.com
Fri Dec 5 00:05:24 CST 2008
I met some problems when I was trying to call a dll in a mpich program
(Language:VS 2005).
(1) MPICH seems to only support calling convention _cdecl.
When I change the project setting to _stdcall, the code cannot be
successfully built.
So I set the project setting back to _cdecl and force the calling
convention of the function pointer to my function on the DLL to be
"_stdcall". This time the program is built.
Under debugging mode or directly run in command window (
c:>test.ext), there is no problem to call dll in the code.
Here is the code:
typedef char (__stdcall *AVRUN) (char[100]);
HINSTANCE ArcviewDLL;
AVRUN AVRun;
ArcviewDLL= LoadLibraryA("Avhelp.dll");
AVRun = (AVRUN) GetProcAddress(ArcviewDLL, "AVRun");
AVRun("av.run(\"HAO_script3\",\"\")");
(2) However, the program fails to call dll when I use "mpiexec" to run
it. (c:>mpiexec -n 1 test.exe).
It seems to "stop" right before this line
Is there anyone having any idea why this happens?
Vivian
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20081205/ca02afd5/attachment.htm>
