[mpich-discuss] Code crashes when compiling with GFORTRAN but not when compiling with PGF90
Rajeev Thakur
thakur at mcs.anl.gov
Mon Dec 1 16:01:45 CST 2008
It's strange. We test with gfortran regularly. Just again make sure you have
compiled and built correctly with gfortran, i.e., both F77 and F90 are set
to gfortran before running configure. Then run make clean and make.
Rajeev
> -----Original Message-----
> From: mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of
> Michael Ahlmann
> Sent: Monday, December 01, 2008 1:11 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: [mpich-discuss] Code crashes when compiling with
> I recently built a new cluster and loaded it with MPICH2
> (1.08) and both
> the PGF90 and GFORTRAN compilers. When I compile MPICH2 and my code
> with PGF90, everything runs without a hitch; however, if I
> compile both
> with GFORTRAN, the code crashes after 1 iteration unless I
> run it on 2
> or less processors. The strange part is that I have successfully
> compiled and run the code on multiple processors using GFORTRAN and
> MPICH2 (1.06) on another cluster, so I am somewhat baffled.
> The error
> message is the following:
> Fatal error in MPI_Waitall: Invalid argument, error stack:
> MPI_Waitall(257): MPI_Waitall(count=8, req_array=0xa0476f8,
> status_array=(nil)) failed
> MPI_Waitall(106): Null pointer in parameter array_of_statuses[cli_0]:
> aborting job:
> rank 0 in job 21 cluster.engr.ucdavis.edu_45821 caused collective
> abort of all ranks
> exit status of rank 0: return code 1
> Has anybody seen a similar problem? Thanks for the help,
> -Michael
