[mpich-discuss] Buffered send and tcp on Windows
Rajeev Thakur
thakur at mcs.anl.gov
Fri Aug 29 13:57:50 CDT 2008
You are sending 1000 integers = 4000 bytes. The buffer is 10000 bytes, so it
has room for only 2 bsends.
Rajeev
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Mikko Lyly
> Sent: Friday, August 29, 2008 1:45 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: [mpich-discuss] Buffered send and tcp on Windows
> Dear all,
> I have a small question related to MPICH2 1.0.7, and I was
> hoping if you could help me to understand the case a little
> bit better.
> Attached to this mail (see below) is a small sample program
> in f90, which fails to run both on Linux and Windows when
> executed as follows:
> $ mpiexec -localonly 4 test
> It runs fine for n=1,2,3. For n=4 and grater, I get:
> Fatal error in MPI_Bsend: Invalid buffer pointer, error stack:
> MPI_Bsend(182).......: MPI_Bsend(buf=0023EE50, count=1000,
> MPI_INTEGER, dest=3, tag=1000, MPI_COMM_WORLD) failed
> MPIR_Bsend_isend(342): Insufficient space in Bsend buffer;
> requested 4000; total buffer size is 10000
> I fail to understand, why is the buffer size not sufficient
> (sending 3000, bufsize is 10000), and why the error is
> "requested 4000"?
> Thank you and have a very nice weekend,
> Mikko Lyly
> PROGRAM test
> IMPLICIT NONE
> INCLUDE 'mpif.h'
> INTEGER :: receiver, sender, rc, ntasks, id
> INTEGER :: status(MPI_STATUS_SIZE)
> INTEGER, PARAMETER :: send_buf_size = 10000
> INTEGER, PARAMETER :: data_buf_size = 1000
> INTEGER :: send_buf(send_buf_size)
> INTEGER :: data_buf(data_buf_size)
> CALL MPI_INIT(rc)
> CALL MPI_COMM_SIZE(MPI_COMM_WORLD, ntasks, rc)
> CALL MPI_COMM_RANK(MPI_COMM_WORLD, id, rc)
> CALL MPI_BUFFER_ATTACH(send_buf, send_buf_size, rc)
> ! Sending (ntasks-1) times 1000 integers (buffer size is 10000):
> DO receiver = 0, ntasks-1
> IF(receiver /= id) THEN
> PRINT *, 'Send:', id, '->', receiver
> CALL MPI_BSEND(data_buf, data_buf_size, MPI_INTEGER,
> receiver, 1000, MPI_COMM_WORLD, rc)
> END IF
> END DO
> ! Receiving (ntasks-1) times 1000 integers:
> DO sender = 0, ntasks-1
> IF(sender /= id) THEN
> PRINT *, 'Recv:', sender, '->', id
> CALL MPI_RECV(data_buf, data_buf_size, MPI_INTEGER,
> sender, 1000, MPI_COMM_WORLD, status, rc)
> END IF
> END DO
> CALL MPI_FINALIZE(rc)
> END PROGRAM test
