[mpich-discuss] Re: MPI_Brecv vs multiple MPI_Irecv
Jeff Squyres
jsquyres at cisco.com
Wed Aug 27 17:20:13 CDT 2008
(Note: this thread is separately spanning the two different MPI
implementation mailing lists...)
On Aug 27, 2008, at 1:51 PM, Robert Kubrick wrote:
>> For mpich2, the internal buffer space is limited by available
>> memory. For each unexpected small message (<=128K for ch3:sock)
>> mpich2 does a malloc and receives the message into that buffer. So
>> even unexpected small messages shouldn't block program flow...but
>> you'll eventually crash if you run out of memory.
> Good to know.
Most MPI implementations use a similar strategy.
> Yes. If you have a process that sends many small messages, such a
> logging strings to a spooler process, by reading the MPI standard
> you're left with the impression that MPI_Send might block until a
> matching receiving has been posted on the other side.
You should always write your code to assume that MPI_SEND *will*
block. Failure to do so will almost certainly result in "my code runs
properly in MPI implementation X, but hangs in MPI implementation
Y" (because X and Y provide differing amounts of internal buffer
space). This is a common complaint among newbie MPI programmers, but
the standard is fairly clear on this point.
> If sender performance is a priority, the solution is to queue those
> log messages somewhere (either on the sending side or better off on
> the receiving side) to let the process continue execution. MPI_Isend
> won't make it because the overhead to manage hundreds of request
> would probably slow down execution more.
Maybe, maybe not (I assume you mean Irecv?). With MPI_Irecv, the
implementation may receive the message directly into your buffer (vs.
an intermediate and then later memcpy). Meaning: assuming that the
performance is offset is not necessarily true.
> If process priority is reversed (sending process has low priority,
> receiving process high), it's probably better to use MPI_Battach/
> MPI_Bsend to move the buffering copy overhead to the sender?
If you have a slow sender and a fast receiver, why not send
immediately? (vs. forcing a buffered send, which will almost
certainly slow down your overall performance)
Jeff Squyres
Cisco Systems
