[mpich-discuss] Re: MPI_Brecv vs multiple MPI_Irecv
Robert Kubrick robertkubrick at gmail.com
Wed Aug 27 13:00:34 CDT 2008
On Aug 27, 2008, at 1:29 PM, Darius Buntinas wrote:
> I'm not sure what you mean by a queue on the receiving side.  If
> receives have been posted, incoming messages that match the posted
> receives will be received directly into the specified location.
Yes, but you have to post receives and keep track of each request
handler. That was the idea of my original question, one recv per
message.
You can receive more than one element/message with each call of course:
MPI_Irecv(buf, 10, ...)
but then the Irecv handler won't be ready until *all* the elements
have been received.
All I am saying is that it would be convenient to specify a receiving
buffer where the implementation can store messages without blocking
program flow on the send side and message transmission.
> Depending on the particular MPI implementation you're using,
> progress on the receives (i.e., taking them off the network, doing
> the matching, copying/receiving into the user buffer, etc.) may
> only happen while you're calling an MPI function call.  So if
> you're in a long compute loop, the MPI library might not be
> performing the receives.  But adding a user buffer wouldn't help
> that situation either.
The program might be on a blocking recv on a different comm, which
could allow progress on a different comm.
Also my understanding is that the MPI standard does not restrict the
progress of MPI send/recv during MPI calls. Some MPI implementations
are multi-threaded.
> Messages that are received which don't have matching posted
> receives will be "queued" waiting for the matching receives, and
> either buffered internally at the receiver (for small messages) or
> will "stall" at the sender (for large messages).  But I believe
> you're only concerned with the case where receives have been posted.
Both cases. By specifying a receiving buffer to handle incoming
messages, the application does not need to post recv to allow
transmission (until there is room left in the buffer of course).
Even for small messages the send might block when all the internal
receiver buffer space is gone. And what is the size of the internal
buffer anyway?
> Does this help?
> -d
> On 08/27/2008 11:03 AM, Robert Kubrick wrote:
>> A buffered receive would allow the implementation to receive and
>> store messages when the application is busy doing something else,
>> like reading messages on a different comm. I now understand why a
>> Brecv is not in the standard and it makes perfect sense, but the
>> result is that on the sending you can control the size of a
>> sending "queue", on the receiving side you can not.
>> On Aug 27, 2008, at 11:23 AM, Darius Buntinas wrote:
>>> Well, what would it mean to do a buffered receive?
>>> This?
>>>   buf = malloc(BUF_SZ);
>>>   MPI_Irecv(buf,...);
>>>   MPI_Wait(...);
>>>   memcpy(recv_ptr, buf, BUF_SZ);
>>> What would be the benefit?
>>> -d
>>> On 08/27/2008 10:13 AM, Robert Kubrick wrote:
>>>> I just found out that the standard actually doesn't have an
>>>> MPI_Brecv call.
>>>> Any reason why the recv can not buffer messages in a user-
>>>> provided memory space, as per MPI_Battach/MPI_Bsend?
>>>> On Aug 26, 2008, at 4:17 PM, Robert Kubrick wrote:
>>>>> From a performance point of view, which one is better:
>>>>> MPI_Battach(10*sizeof(MSG))
>>>>> MPI_Brecv()
>>>>> or
>>>>> MPI_recv_init()
>>>>> MPI_recv_init()
>>>>> MPI_recv_init()
>>>>> ... /* 10 recv handlers */
>>>>> MPI_Start(all recv)
>>>>> MPI_Waitany()
>>>>> I understand MPI_Brecv will require an extra message copy, from
>>>>> the attached buffer to the MPI_Brecv() buffer. I'd like to know
>>>>> if there other differences between the two methods.
>>>>> Thanks,
>>>>> Rob
