[mpich-discuss] RE: Questions about connecting other computers (using other CPUs)
Jayesh Krishna jayesh at mcs.anl.gov
Wed Aug 27 11:52:25 CDT 2008
 To use multiple nodes/hosts/machines to run your MPI application,
=========== SETUP =================
# Install MPICH2 on all the machines/hosts/nodes involved.
=========== TESTING YOUR SETUP ================
# Try running a non-MPI program using the "-machinefile" option of mpiexec
(List the ipaddresses/hostnames(Try ipaddresses first) of the machines in
the machinefile ). See the windows developer's guide for details on using
the "-machinefile" option.
    --- Try running,
            mpiexec -n 2 -machinefile my_machine_file.txt hostname
# If you run hostname as mentioned in the prev step using mpiexec, you
should see the hostnames of the indiv machines listed.
# Now try running cpi.exe (MPICH2\examples\cpi.exe) using the
"-machinefile" option of mpiexec.
=========== RUNNING YOUR PROGRAM =============
# Make your application available on all the machines
   1) You can copy your application to the same location on all the
machines (Try this first)
        OR
   2) You can copy your application to diff locations in each machine and
use the "-path" option in mpiexec to specify the path in each machine (see
the windows developer's guide for details)
        OR
    3) Use the "-map" or "-mapall" option of mpiexec to map the directory
containing the executable on all the machines (see the windows developer's
guide for details)
# Run your MPI program using the "-machinefile" option of mpiexec (List
the ipaddresses/hostnames(Try ipaddresses first) of the machines in the
machinefile )
  Let us know if you need further help.
(PS: By the way, if you have 2 CPUs in your machine if you run your MPI
application with more than 1 process, the OS schedules the processes to
use both processors.)
Jayesh
  _____
Sent: Wednesday, August 27, 2008 11:33 AM
To: 'Jayesh Krishna'
Subject: RE: Questions about connecting other computers (using other CPUs)
HI Jayesh,
My computer has only 2 CPUs so I cannot find any advantages for using MPI
application.
Now I'm trying to connect other computers to use CPUs for my MPI code.
Could you tell me how I can connect with other computers and apply my MPI
code?
Hyoun-Tae
Hyoun-Tae Hwang
#2051 EIT, Department of Earth and Environmental Sci
University of Waterloo
office : (+1) 519-888-4567 (EXT. 37343)
home : (+1) 519-880-9794
-----Original Message-----
From: Jayesh Krishna [mailto:jayesh at mcs.anl.gov]
Sent: August 18, 2008 1:58 PM
To: 'Hyoun-Tae'
Subject: RE: Questions about MPI application
 Great! Let us know if you need any further help.
Jayesh
  _____
Sent: Monday, August 18, 2008 12:57 PM
Hello,
Thanks for your help. As you said, I debugged my code.
I finally got right results. It really works!
I appreciate your help.
HT
Hyoun-Tae Hwang
Sent: August 14, 2008 12:37 PM
To: 'Hyoun-Tae'
Cc: mpich-discuss at mcs.anl.gov
 The error "Error creating mpiexec process" indicates that you have tried
to run a singleton MPI process without mpiexec in the PATH. Make sure that
you have mpiexec in your PATH (more precisely the path to mpiexec in your
PATH env variable) when running an MPI process as a singleton process
(singleton process - process launched without mpiexec - when you run your
MPI process in the VS command window). To get rid of the error I would
recommend that you run your MPI application from a command window using
mpiexec OR run your MPI application from a command window without mpiexec
but making sure that path to mpiexec (typically c:\program
files\mpich2\bin) is in the PATH.
 The error "process 0 exited without calling finalize" can happen due to
many reasons (Basically the error just says that the MPI process exited
before calling MPI_Finalize()). Most likely it is due to an error in the
application resulting in a segfault, aborting the job. I would recommend
that, to start with your debugging, you run your application using mpiexec
from a command prompt and try debugging the application with some debug
statements.
 Let us know if you need further assistance
Jayesh
  _____
Sent: Thursday, August 14, 2008 10:47 AM
To: jayesh at mcs.anl.gov
Subject: Questions about MPI application
Hello Jayesh,
I just make an MPI application code, which solves non-linear PDEs.
Of the code, I applied parallel computing method only on a matrix solver,
Thomas algorithm.
The scheme of my program follows as:
1.      read input data
2.      make a matrix
3.      solve the matrix by using parallel method
4.      print output
As mentioned before, I just parallelized only the matrix solver.
I compiled the application code by using MS visual studio 2005
and executed the application code with using MPIEXEC wrapper.
However, I always got an error massage like (I'm using 2 CPUs)
job aborted:
rank: node: exit code[: error message]
0: hthwang: -1073741819: process 0 exited without calling finalize
1: hthwang: -1073741819: process 1 exited without calling finalize
Could you tell me why I always get the error message and how I can solve
this problem?
When I compile the code by using MS visual studio 2005,
I also get a message on a command window such as:
[0] Error creating mpiexec process .2
[0] launchMpiexecProcess failed
Fatal error in MPI_Init: Other MPI error, error stack:
MPIR_Init_thread(294): Initialization failed
MPID_Init(82)....: channel initialization failed
MPID_Init(383).....: PMI_Get_id returned 1
Is this error after compilation related to MPI application error?
Could you tell me how I can solve these problems?
I can send the MPI application code if you need.
Thank you,
HT
Hyoun-Tae Hwang
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080827/95d8e3eb/attachment.htm>
