[mpich-discuss] mpdboot fails
Rajeev Thakur
thakur at mcs.anl.gov
Tue Aug 26 18:11:04 CDT 2008
-mpd just specifies the path for mpd on remote hosts (the same path for all
remote hosts). If it still doesn't work, there may be some problem with the
networking configuration on the two machines. To debug the problem, you can
use the mpdcheck utility as described in the installation guide (all steps).
Rajeev
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Robert Kubrick
> Sent: Tuesday, August 26, 2008 6:05 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] mpdboot fails
> I'm not clear on how --mpd works: I want to specify two
> different paths, one for the local machine and one for the
> remote host (or possibly a number of different remote hosts).
> Here it looks like I can only set one path for all the hosts:
> $ mpdboot --verbose --totalnum=2
> --mpd=/usr/local/mpich2/bin/mpd --debug
> debug: starting
> running mpdallexit on iMac.local
> LAUNCHED mpd on iMac.local via
> debug: launch cmd= /usr/local/mpich2/bin/mpd --ncpus=1 -e -d
> debug: mpd on iMac.local on port no_port mpdboot_iMac.local
> (handle_mpd_output 406): from mpd on iMac.local, invalid port info:
> no_port
> $ mpdboot --verbose --totalnum=2 --debug
> debug: starting
> debug: launch cmd= /opt/local/mpich2/bin/mpd.py --ncpus=1 -e -d
> debug: mpd on iMac.local on port 62629
> RUNNING: mpd on iMac.local
> debug: info for running mpd: {'ncpus': 1, 'list_port': 62629,
> 'entry_port': '', 'host': 'iMac.local', 'entry_host': '',
> 'ifhn': ''} LAUNCHED mpd on wlaptop via iMac.local
> debug: launch cmd= ssh -x -n -q wlaptop
> '/opt/local/mpich2/bin/ mpd.py -h iMac.local -p 62629
> --ncpus=1 -e -d'
> debug: mpd on wlaptop on port no_port
> mpdboot_iMac.local (handle_mpd_output 406): from mpd on
> wlaptop, invalid port info:
> no_port
> On Aug 25, 2008, at 2:20 PM, Rajeev Thakur wrote:
> >> The path to mpd on 'wlaptop' is actually a different one than on
> >> iMac.local. How can I specify a different remote path for mpd?
> > With the --mpd option to mpdboot.
> > Rajeev
> Robert Kubrick
> >> Sent: Sunday, August 24, 2008 5:19 PM
> >> Subject: [mpich-discuss] mpdboot fails
> >> mpdboot fails when I try to run with this command:
> >> # mpdboot --totalnum=2 --verbose -d debug: starting
> >> debug: mpd on iMac.local on port 61785
> >> debug: info for running mpd: {'ncpus': 1, 'list_port': 61785,
> 'ifhn': ''}
> >> debug: launch cmd= ssh -x -n -q wlaptop '/opt/local/mpich2/bin/
> >> mpd.py -h iMac.local -p 61785 --ncpus=1 -e -d'
> >> debug: mpd on wlaptop on port no_port mpdboot_iMac.local
> >> (handle_mpd_output 406): from mpd on wlaptop, invalid port info:
> >> no_port
