[mpich-discuss] ctrl-c while running mpiexec -gdb
Robert Kubrick
robertkubrick at gmail.com
Tue Aug 12 14:08:50 CDT 2008
I tried this:
my-computer:~ mycomputer$ mpdlistjobs
jobid = 6 at mycomputer.local_57025
jobalias =
username = mycomputer
host = mycomputer.local
pid = 15490
sid = 15488
rank = 1
pgm = demo
jobalias =
pid = 15491
sid = 15489
rank = 2
pgm = demo
jobalias =
pid = 15492
sid = 15487
rank = 0
pgm = demo
mycomputer:~ mycomputer$ mpdsigjob SIGINT -j 6 at mycomputer.local_57025
But the SIGINT causes a collective abort:
rank 1 in job 6 mycomputer.local_57025 caused collective abort of
all ranks
exit status of rank 1: killed by signal 9
rank 0 in job 6 mycomputer.local_57025 caused collective abort of
all ranks
exit status of rank 0: killed by signal 9
On Aug 12, 2008, at 1:24 PM, Darius Buntinas wrote:
> When you hit ^C from mpiexec (with or without -gdb), mpiexec will
> kill all processes and exit. To send a SIGINT to the processes
> themselves, you would need to use mpdsigjob. First find the jobid
> using mpdlistjobs, then send the SIGINT to the job:
> mpdsigjob SIGINT -j jobid
> Give this a try.
> -d
> On 08/12/2008 11:23 AM, Robert Kubrick wrote:
>> When I run a regular program under gdb, ctrl-c returns control to
>> the gdb prompt and I can examine the stack of the interrupted
>> process or issue any other gdb command on the current process.
>> When running mpiexec -gdb, ctrl-c returns to the shell (thus
>> abandoning the gdb session).
>> On Aug 12, 2008, at 10:52 AM, Rajeev Thakur wrote:
>>> You should be able to type gdb commands at the prompt returned by
>>> mpiexec
>>> -gdb.
>>> Rajeev
>>>> -----Original Message-----
>>>> From: owner-mpich-discuss at mcs.anl.gov
>>>> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Robert
>>>> Kubrick
>>>> Sent: Monday, August 11, 2008 10:16 PM
>>>> To: mpich-discuss at mcs.anl.gov
>>>> Subject: [mpich-discuss] ctrl-c while running mpiexec -gdb
>>>> In mpiexec -gdb hitting ctrl-c terminates all the processes
>>>> of the MPI program. I want to read the stack for one of the
>>>> MPI process while the program is running, is there a way to
>>>> let ctrl-c return control to gdb rather then quitting the
>>>> program alltogether?
