[mpich-discuss] MPI_Irecv does block
Robert Kubrick robertkubrick at gmail.com
Mon Aug 11 21:22:43 CDT 2008
I want to send a number of elements through MPI_Send. However the
receiving process does not know the maximum number of elements in the
array (it might be very large). The code will look something like:
MASTER:
char buf[500];
MPI_Send(&buf, 500, SomeDerivedType, 1, ...);
WORKER:
char buf[100];
const int Master = 0;
MPI_Irecv(&buf, 100, SomeDerivedType, Master, ...);
I noticed that here the worker process blocks (despite the MPI_Irecv
non-blocking call) because it doesn't have enough room in the buffer
to receive all the elements. I know one way to solve the problem is
to use MPI_Probe, but is this the expected behavior if the buffer is
too small? Shouldn't MPI_Irecv return an error to avoid blocking?
