[mpich-discuss] Using 32 bit as rank
wei huang huanwei at cse.ohio-state.edu
Tue Aug 5 17:27:32 CDT 2008
Hi list,
We here are trying to run mvapich2, which is based on mpich2-1.0.7, on
more than 32k processes. However, we find that MPIDI_Message_match
structure uses only int16_t as the rank. This is not enough for job larger
than 32k. It looks like the follow change that uses int32_t for rank is
needed to scale. Would you consider integrate this change in future mpich2
releases? Thanks.
Index: src/mpid/ch3/include/mpidpre.h
--- src/mpid/ch3/include/mpidpre.h      (revision 2891)
+++ src/mpid/ch3/include/mpidpre.h      (revision 2892)
@@ -65,7 +65,7 @@
 typedef struct MPIDI_Message_match
     int32_t tag;
-    int16_t rank;
+    int32_t rank;
     int16_t context_id;
 MPIDI_Message_match;
Wei Huang
774 Dreese Lab, 2015 Neil Ave,
Dept. of Computer Science and Engineering
Ohio State University
OH 43210
Tel: (614)292-8501
