[mpich-discuss] FW: SMPD on Linux with firewall turned on
Jayesh Krishna jayesh at mcs.anl.gov
Mon Aug 4 10:23:25 CDT 2008
  You might also have to open up the port used by SMPD to listen for
incoming connections (port 8676 by default --- Or use the "-port" option
while starting smpd to specify the port to listen. If you use the "-port"
option with smpd make sure that you specify the same port number when
running your job using mpiexec.)
  Let us know if it works for you.
(PS: If that does not work please run smpd and mpiexec in verbose/debug
mode and send us the output. smpd -d / mpiexec -verbose. Also send us the
complete error message that you get when running your MPI application.)
Jayesh
-----Original Message-----
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Rajeev Thakur
Sent: Saturday, August 02, 2008 11:03 AM
Subject: [mpich-discuss] FW: SMPD on Linux with firewall turned on
Date: Fri, 1 Aug 2008 16:01:57 -0700 (PDT)
Message-Id: <200808012301.m71N1vej028741 at celerio.ucdavis.edu>
Subject: SMPD on Linux with firewall turned on
I installed MPICH2 on 2 64-bit Linux machines under my home directory.
The firewall of both machines is turned on.
When I ran a program across these 2 machines, I got an error message such
as
"abort: unable to connect to xxx".
So I checked with the system administrator and he enabled 11 TCP ports for
me to use.
The port range is from 12505 to 12515.
Also, I set the MPICH_PORT_RANGE environment variable with the above
range.
However, I still got the same error message as mentioned before.
So, how to fix this problem?
Thank you very much,
-Yucheng
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080804/484b8b2a/attachment.htm>
