[mpich-discuss] C++ for Visual studio code
    Gholamreza Sobhaninejad
    grsobhani at gmail.com
    Sun Aug  3 19:47:49 CDT 2008
Hi rebecca,
I was using vs 2005 and vs 2008. But since there are some inconsistencies
between VS compilers and Linux based compilers, I am not using VS for
programming.
I wanna suggest you  if you are going to use clusters which use Linux OP
just move to Netbeans or Eclipse IDEs and compile your code with GNU or
Intel compileres.
Anyway, as I see you are in correct tab but please have a look in
Input,System and Advanced section too. It should be somewhere there.
Additional libraries directory should be set to MPI->LIB directory. But
still you need to link mpichxx and mpich to your code.
Please don't hesitate to ask question.
Sincerely,
Reza
On Mon, Aug 4, 2008 at 9:18 AM, Rebecca <rebeccakern at sbcglobal.net> wrote:
>  Thank you for responding Reza!  I am having trouble seeing the additional
> dependencies in VS .NET 2003.  What version of VS do you use?
> *From:* owner-mpich-discuss at mcs.anl.gov [mailto:
> owner-mpich-discuss at mcs.anl.gov] *On Behalf Of *Gholamreza Sobhaninejad
> *Sent:* Saturday, August 02, 2008 9:18 PM
> *To:* mpich-discuss at mcs.anl.gov
> *Subject:* Re: [mpich-discuss] C++ for Visual studio code
> Hi Rebecca,
> When you use MPICH with C++ , you need to link "mpicxx" and "mpich"
> libraries. you can determine this two file in project properties/
> Linker/Additional Dependencies.
> Reza
> On Sun, Aug 3, 2008 at 8:13 AM, Rebecca <rebeccakern at sbcglobal.net> wrote:
> I am having trouble accessing the MPI.h library from C++ in Visual Studio.
> I am getting an unresolved external symbol for MPI::Init() and if I try to
> use MPI_Init() the code ends unexpectedly.  I am able to use MPI_Init() in c
> without any problem.  Does anyone have sample code I could see with C++?
> Gholamreza Sobhaninejad(Reza)
> PhD candidate, University of Tokyo
> Earthquake Research Institute
> Tel: 090-9807-2477
Tel: 090-9807-2477
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080804/2cf03a10/attachment.htm>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080804/2cf03a10/attachment.jpeg>
