[mpich-discuss] MPI_Recv: MPI + Pthreads
    Olya Krachina
    okrachin at purdue.edu
    Tue Apr 22 23:16:06 CDT 2008
> Can you send us a sample code that fails? I'm assuming you are using
> mpich2-1.0.7 (the latest version).
yes, i am using latest version, here's a portion of the code:
#define NUMTHREADS 8
pthread_t threads[NUMTHREADS];
#define TAG_MATRIX_PARTITION	0x1234
typedef struct
{  unsigned int   m, n;  // Rows, cols
   int        *data;  // Data, ordered by row, then by col
   int       **rows;  // Pointers to rows in data
} TMatrix;
// Globals
int processor_rank  = 0;
int processor_count = 1;
typedef struct
        TMatrix A;
        TMatrix B;
        TMatrix C;
        int thread_id;
} thread_args; //pass this to the threads
thread_args thread_data[NUMTHREADS];
int main (int argc, char *argv[])
{  MPI_Status   status;
   TMatrix      A,B,C,D;
      MPI_Init(&argc, &argv)
      MPI_Comm_size (MPI_COMM_WORLD, &processor_count);
      MPI_Comm_rank (MPI_COMM_WORLD, &processor_rank );
      if (processor_rank == 0)
      	printf ("Enter matrix dimension n : "); scanf("%u", &n);
         // Allocate memory for matrices
	 // Initialize matrices
         // Broadcast (send) size of matrix
         MPI_Bcast((void *)&n, 1, MPI_INT, 0, MPI_COMM_WORLD);
         m = n / processor_count;
         // Broadcast (send) B matrix
         MPI_Bcast((void *)B.data, n*n, MPI_INT, 0, MPI_COMM_WORLD);
         // Send each process it's own part of A
	 offset = n - m * (processor_count - 1);
	 for (i = 1; i < processor_count; i++)
	    MPI_Send((void *)A.rows[offset], m*n, MPI_INT,
	             i, TAG_MATRIX_PARTITION, MPI_COMM_WORLD);
	    offset += m; //update teh offset
	 A.m = n - m * (processor_count -1);
	 for (x = 0; x < NUMTHREADS; x++)
                        //pass in the structure A, B, C and thread_id;
                        thread_data[x].A = A;
                        thread_data[x].B = B;
                        thread_data[x].C = C;
                        thread_data[x].thread_id = x;
                        pthread_create(&threads[x], NULL, doMyWork,
                           (void*)&thread_data[x]);
                        pthread_join(threads[x], NULL);
	 	A.m = n; //reset A's dimension
	 // Receive part of C matrix from each process
	 	//something is WROOOONG here!
	 	MPI_Recv((void *)C.rows[offset], m*n, MPI_INT,
	             i, TAG_MATRIX_PARTITION, MPI_COMM_WORLD, &status);
	        offset += m;
      else
         // Broadcast (receive) size of matrix
	 A = createMatrix(m, n); //A is of a different size
	 B = createMatrix(n ,n);
         // Broadcast (receive) B matrix, everyone has to do this
	 MPI_Recv((void *)A.data, m*n, MPI_INT, 0, TAG_MATRIX_PARTITION,
                 MPI_COMM_WORLD, &status[0]);
	  MPI_Send((void *)C.data, m*n, MPI_INT, 0,
                TAG_MATRIX_PARTITION,MPI_COMM_WORLD);
   MPI_Barrier(MPI_COMM_WORLD);
   MPI_Finalize();
   pthread_exit(NULL);
   return 0;
each thread does this: it basically takes a portion of A assigned to this MPI
process and splits it in narrower strips of rows, performs multiplication and
returns part of resulting matrix.
void *doMyWork(void *thread_datas)
        int i, j, k, r, N;
        thread_args *my_data_ptr = NULL;
        my_data_ptr = (thread_args *)thread_datas;
        int Id = my_data_ptr->thread_id; //thread_id
        int A_rows = 0;
        TMatrix myA, myB, myC;
        myA = my_data_ptr->A;
        myB = my_data_ptr->B;
        myC = my_data_ptr->C;
        N = my_data_ptr->B.n;
        A_rows = my_data_ptr->A.m;
        int from = (Id*A_rows) >> 3;
        int to = ((Id+1)*A_rows) >> 3;
        for (i = from;  i < to; i++)
          for (j = 0; j < N; j++)
             r = 0;
             for (k = 0; k < N; k++)
                r = r +  myA.rows[i][k]*myB.rows[k][j];
                myC.rows[i][j] = myC.rows[i][j] + r;
> Btw, the most common error people make while using threads (assuming all
> threads perform MPI calls) is to use MPI_Init() -- you should use
> MPI_Init_thread().
I will try that..... i am not sure what you mean, but i am using threads on
each MPI process, i.e. one MPI is an 8-pthread application.
thanks again.
