[mpich-discuss] MPICH2 + QT4 Try to run GUI program on several hosts
Jayesh Krishna jayesh at mcs.anl.gov
Tue Apr 22 11:43:31 CDT 2008
  If you are sharing your executable (\\alopatin\mpich\Lab_MPI.exe) over the
network you must make sure that specify the mapped drive in the mpiexec
command (see the "-map" option for mpiexec in the window's developer's guide
- available at
http://www.mcs.anl.gov/research/projects/mpich2/documentation/index.php?s=do
cs)
 Let us know if it works for you.
Jayesh
-----Original Message-----
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of ?????? ???????
Sent: Tuesday, April 22, 2008 1:06 AM
Subject: RE: [mpich-discuss] MPICH2 + QT4 Try to run GUI program on several
hosts
Hi
When i run such command (mpiexec -localroot -pwdfile \\alopatin\mpich\login
-hosts 2 alopatin 1 alvirt 1 hostname) names of hosts show correctly. And if
i use examples such as cpi all work correctly too.
