[mpich-discuss] Socket error on Quad-core Windows XP
Jayesh Krishna jayesh at mcs.anl.gov
Mon Apr 14 09:10:13 CDT 2008
  Is there any reason you want to use the "-localonly" option ?
(PS: The "closesocket()" errors that you see are due to a subtle bug in the
smpd state machine where a socket is closed twice. This should not affect
your program. We will fix this bug in the next release. These messages show
up since you are using the "-localonly" option.)
Jayesh
-----Original Message-----
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Gib Bogle
Sent: Sunday, April 13, 2008 8:13 PM
Subject: Re: [mpich-discuss] Socket error on Quad-core Windows XP
I am running on an Intel Core 2 Quad CPU Q6600 PC, under Windows XP.  I
simply downloaded and installed the latest binary distribution for Windows,
mpich2-1.0.7-win32-ia32.msi.  There was no configuration that I noticed.
The process manager is smpd, which is started automatically.
The invocation of my program is:
mpiexec -localonly 3 simple.exe
A simple version of the code follows.  I found a couple of interesting
things.  There are many more 10093 errors with 3 processors than with 4.
Uncommenting the deallocate statement in the main program seems to eliminate
10093 errors, but I still get the occasional 10058 error.  It seems that
MPICH2 gets upset if memory allocated after MPI_INIT() is not deallocated
before MPI_FINALIZE().  Note that errors occur intermittently - not every
run.
Cheers
Gib
Code:
! FILE: simple.f90
! This exhibits socket errors
module mpitest
use mpi
IMPLICIT NONE
integer, parameter :: NDATA = 100
integer, parameter :: NX = 50, NY = NX, NZ = NX
type occupancy_type
     integer :: cdata(NDATA)
end type
type(occupancy_type), allocatable :: occupancy(:,:,:) integer :: me,
my_cell_type
contains
subroutine mpi_initialisation
integer :: size, ierr, status(MPI_STATUS_SIZE)
CALL MPI_INIT(ierr)
CALL MPI_COMM_RANK( MPI_COMM_WORLD, me, ierr ) CALL MPI_COMM_SIZE(
MPI_COMM_WORLD, size, ierr ) end subroutine
subroutine array_initialisation
integer :: x,y,z,k
allocate(occupancy(NX,NY,NZ))
k = 0
do x = 1,NX
     do y = 1,NY
		do z = 1,NZ
	        k = k+1
             occupancy(x,y,z)%cdata = k
		enddo
     enddo
enddo
end subroutine
end module
PROGRAM simple
use mpitest
integer :: ierr
call mpi_initialisation
call array_initialisation
call MPI_BARRIER ( MPI_COMM_WORLD, ierr )
!deallocate(occupancy)
write(*,*) 'MPI_FINALIZE: ',me
CALL MPI_FINALIZE(ierr)
END
Pavan Balaji wrote:
> Do you have a very simple (as simple as possible) program that
> demonstrates this? Also, can you give some more information about your
> installation --
> 1. Which version of MPICH2 are you using?
> 2. What configuration options were passed to MPICH2 during
> configuration
> 3. What process manager are you using?
> 4. What command line did you use to launch the process manager?
> 5. What command line did you use to launch the program?
> 6. Anything other information we should probably know about in your
> cluster, e.g., what OS, is there a firewall between the nodes, etc.
>  -- Pavan
> On 04/09/2008 09:49 PM, Gib Bogle wrote:
>> My mpich-2 program seems to run correctly, but when it tries to
>> execute MPI_Finalize() it gives a range of error messages, all
>> apparently related to closing the socket connections.  Typical
>> messages are:
>> unable to read the cmd header on the pmi context, socket connection
>> closed
>> shutdown failed, sock ####, error 10093
>> closesocket failed, sock ####, error 10093
>> So far I haven't seen any bad consequences from these errors, but
>> they are disconcerting.  Should I care?  Is there something I can do?
>> Gib
