[MPICH] An idle communication process use the same CPU as computation process on multi-core chips
Bob Soliday
soliday at aps.anl.gov
Tue Sep 25 13:22:40 CDT 2007
Pretty cool to see my bug report made it all the way up to Linus Torvalds.
Darius Buntinas wrote:
> Hmm. Maybe things aren't as bad as I thought. It looks like Linus is
> pushing for the previous yield() behavior.
> http://kerneltrap.org/Linux/CFS_and_sched_yield
> -d
> On 09/18/2007 01:23 PM, Darius Buntinas wrote:
>> From the discussion on lkml and the fact that they see programs that
>> use sched_yield() this way as "fundamentally broken", it seems that
>> this patch is only temporary, and eventually the pre-2.6.22 kernel
>> behavior won't be supported.
>> -d
>> On 09/18/2007 12:45 PM, Bob Soliday wrote:
>>> Well I reported the bug and it turns out they already have a patch
>>> for it that will be included in a future release so that it will be
>>> possible to emulate the old scheduler.
>>> https://bugzilla.redhat.com/show_bug.cgi?id=295071
>>> http://lkml.org/lkml/2007/9/14/157
>>> --Bob
>>> Bob Soliday wrote:
>>>> It turns out the problem is not related to the number of cores. Only
>>>> the newest versions of the Fedora 7 kernel show the problem. I think
>>>> it is related to the CFS scheduler in these kernels.
>>>> When I run one slave and one master on the same core with
>>>> kernel-2.6.21-1.3194 using Darius's slave code I see the slave task
>>>> use 100% of the CPU and see the same timing values as when I run the
>>>> slave on a different core.
>>>> When I do the same test with kernel-2.6.22.4-65 or
>>>> kernel-2.6.22.5.76 the timing values double as the slave can only
>>>> get 50% of the CPU time when on the same core.
>>>> --Bob
>>>>> I can verify that I saw the same problem Yusong did when starting
>>>>> the master first on a dual quadcore machine. But assigning each
>>>>> slave to its own core (using taskset) fixed that.
>>>>> Interestingly, when there are less than 8 slaves, top shows that
>>>>> the master has 100% usage (when top is in "irix mode", and 12.5%
>>>>> (1/8) when not in irix mode). When I have 8 slaves, the usage of
>>>>> the master process goes to 0.
>>>>> Yusong, I'm betting that if you set the cpu affinity for the
>>>>> slaves, you'll see no impact of the master on the slaves. Can you
>>>>> try that?
>>>>> e.g.,:
>>>>> ./master &
>>>>> for i in `seq 0 3` ; do taskset -c $i ./slave & done
>>>>> -d
>>>>> On 09/17/2007 02:31 AM, Sylvain Jeaugey wrote:
>>>>>> This seems to be the key of the problem. When the master is
>>>>>> launched before others, it takes one CPU and this won't change
>>>>>> until for any scheduling reason he comes to share its CPU (with a
>>>>>> slave). It then falls to 0% and we're saved.
>>>>>> So, to conduct you experiment, you definetely need to taskset your
>>>>>> slaves. Just launch them with
>>>>>> taskset -c <cpu> ./slave (1 process per cpu)
>>>>>> or use the -p option of taskset to do it after launch and ensure
>>>>>> that each slave _will_ take one CPU. Thus, the master will be
>>>>>> obliged to share the cpu with others and sched_yield() will be
>>>>>> effective.
>>>>>> Sylvain
>>>>>> On Sun, 16 Sep 2007, Yusong Wang wrote:
>>>>>>> I did the experiments on four types of muti-core chips (2
>>>>>>> dual-core, 1 quad-core and 1 eight-core). All of my tests shows
>>>>>>> the idle master process has a big impact on the other slave
>>>>>>> processes except for the test of the quad-core, in which I found
>>>>>>> the order does matter: when the master was launched after the
>>>>>>> slave processes were launched, there is no affect, while if the
>>>>>>> master started first, two slaves processes would go to the same
>>>>>>> core and cause the two processes to slow down significantly than
>>>>>>> others.
>>>>>>> Yusong
>>>>>>> ----- Original Message -----
>>>>>>> From: Darius Buntinas <buntinas at mcs.anl.gov>
>>>>>>> Date: Friday, September 14, 2007 12:55 pm
>>>>>>> Subject: Re: [MPICH] An idle communication process use the same
>>>>>>>> It's possible that different versions of the kernel/os/top compute
>>>>>>>> %cpu
>>>>>>>> differently. "CPU utilization" is really a nebulous term. What
>>>>>>>> you
>>>>>>>> really want to know is whether the master is stealing significant
>>>>>>>> cycles
>>>>>>>> from the slaves. A test of this would be to replace Sylvain's
>>>>>>>> slave
>>>>>>>> code with this:
>>>>>>>> #include <sys/time.h>
>>>>>>>> int main() {
>>>>>>>> while (1) {
>>>>>>>> int i;
>>>>>>>> struct timeval t0,t1;
>>>>>>>> double usec;
>>>>>>>> gettimeofday(&t0, 0);
>>>>>>>> for (i = 0; i < 100000000; ++i)
>>>>>>>> gettimeofday(&t1, 0);
>>>>>>>> usec = (t1.tv_sec * 1e6 + t1.tv_usec) - (t0.tv_sec * 1e6 +
>>>>>>>> t0.tv_usec);
>>>>>>>> printf ("%8.0f\n", usec);
>>>>>>>> return 0;
>>>>>>>> This will repeatedly time the inner loop. On an N core system, run
>>>>>>>> N of
>>>>>>>> these, and look at the times reported. Then start the master and
>>>>>>>> see if
>>>>>>>> the timings change. If the master does steal significant cycles
>>>>>>>> from
>>>>>>>> the slaves, then you'll see the timings reported by the slaves
>>>>>>>> increase.
>>>>>>>> On my single processor laptop (fc6, 2.6.20), running one slave, I
>>>>>>>> see
>>>>>>>> no impact from the master.
>>>>>>>> Please let me know what you find.
>>>>>>>> As far as slave processes hopping around on processors, you can set
>>>>>>>> processor affinity ( http://www.linuxjournal.com/article/6799 has a
>>>>>>>> good
>>>>>>>> description) on the slaves.
>>>>>>>> -d
>>>>>>>>>> That's unfortunate.
>>>>>>>>>> Still, I did two programs. A master :
>>>>>>>>>> int main() {
>>>>>>>>>> while (1) {
>>>>>>>>>> sched_yield();
>>>>>>>>>> return 0;
>>>>>>>>>> and a slave :
>>>>>>>>>> int main() {
>>>>>>>>>> while (1);
>>>>>>>>>> return 0;
>>>>>>>>>> I launch 4 slaves and 1 master on a bi dual-core machine. Here
>>>>>>>> is the
>>>>>>>>>> result in top :
>>>>>>>>>> PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+
>>>>>>>> COMMAND>> 12361 sylvain 25 0 2376 244 188 R 100 0.0
>>>>>>>> 0:18.26 slave
>>>>>>>>>> 12362 sylvain 25 0 2376 244 188 R 100 0.0 0:18.12
>>>>>>>>>> slave
>>>>>>>>>> 12360 sylvain 25 0 2376 244 188 R 100 0.0 0:18.23
>>>>>>>>>> slave
>>>>>>>>>> 12363 sylvain 25 0 2376 244 188 R 100 0.0 0:18.15
>>>>>>>>>> slave
>>>>>>>>>> 12364 sylvain 20 0 2376 248 192 R 0 0.0 0:00.00
>>>>>>>>>> master
>>>>>>>>>> 12365 sylvain 16 0 6280 1120 772 R 0 0.0 0:00.08 top
>>>>>>>>>> If you are seeing 66% each, I guess that your master is not
>>>>>>>>>> sched_yield'ing as much as expected. Maybe you should look at
>>>>>>>>>> environment variables to force yield when no message is
>>>>>>>> available, and
>>>>>>>>>> maybe your master isn't so idle after all and has message to
>>>>>>>> send
>>>>>>>>>> continuously, thus not yield'ing.
>>>>>>>>> On our FC5 nodes with 4 cores we get similar results. But on our
>>>>>>>> FC7
>>>>>>>>> nodes with 8 cores we don't. The kernel seems to think that all 9
>>>>>>>> jobs
>>>>>>>>> require 100% and they end up jumping from one core to another.
>>>>>>>> Often the
>>>>>>>>> master job is left on it's own core while two slaves run on
>>>>>>>>> another.
>>>>>>>>> PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ P
>>>>>>>> COMMAND> 20127 ywang25 20 0 106m 22m 4168 R 68 0.5
>>>>>>>> 0:06.84 0 slave
>>>>>>>>> 20131 ywang25 20 0 106m 22m 4184 R 73 0.5 0:07.26 1
>>>>>>>>> slave
>>>>>>>>> 20133 ywang25 20 0 106m 22m 4196 R 75 0.5 0:07.49 2
>>>>>>>>> slave
>>>>>>>>> 20129 ywang25 20 0 106m 22m 4176 R 84 0.5 0:08.44 3
>>>>>>>>> slave
>>>>>>>>> 20135 ywang25 20 0 106m 22m 4176 R 73 0.5 0:07.29 4
>>>>>>>>> slave
>>>>>>>>> 20132 ywang25 20 0 106m 22m 4188 R 70 0.5 0:07.04 4
>>>>>>>>> slave
>>>>>>>>> 20128 ywang25 20 0 106m 22m 4180 R 78 0.5 0:07.79 5
>>>>>>>>> slave
>>>>>>>>> 20130 ywang25 20 0 106m 22m 4180 R 74 0.5 0:07.45 6
>>>>>>>>> slave
>>>>>>>>> 20134 ywang25 20 0 106m 24m 6708 R 80 0.6 0:07.98 7
>>>>>>>> master>
>>>>>>>>> 20135 ywang25 20 0 106m 22m 4176 R 75 0.5 0:14.75 0
>>>>>>>>> slave
>>>>>>>>> 20132 ywang25 20 0 106m 22m 4188 R 79 0.5 0:14.96 1
>>>>>>>>> slave
>>>>>>>>> 20130 ywang25 20 0 106m 22m 4180 R 99 0.5 0:17.32 2
>>>>>>>>> slave
>>>>>>>>> 20129 ywang25 20 0 106m 22m 4176 R 100 0.5 0:18.44 3
>>>>>>>>> slave
>>>>>>>>> 20127 ywang25 20 0 106m 22m 4168 R 75 0.5 0:14.36 4
>>>>>>>>> slave
>>>>>>>>> 20133 ywang25 20 0 106m 22m 4196 R 96 0.5 0:17.09 5
>>>>>>>>> slave
>>>>>>>>> 20131 ywang25 20 0 106m 22m 4184 R 78 0.5 0:15.02 6
>>>>>>>>> slave
>>>>>>>>> 20128 ywang25 20 0 106m 22m 4180 R 99 0.5 0:17.70 6
>>>>>>>>> slave
>>>>>>>>> 20134 ywang25 20 0 106m 24m 6708 R 100 0.6 0:17.97 7
>>>>>>>> master>
>>>>>>>>> 20130 ywang25 20 0 106m 22m 4180 R 87 0.5 0:25.99 0
>>>>>>>>> slave
>>>>>>>>> 20132 ywang25 20 0 106m 22m 4188 R 79 0.5 0:22.83 0
>>>>>>>>> slave
>>>>>>>>> 20127 ywang25 20 0 106m 22m 4168 R 75 0.5 0:21.89 1
>>>>>>>>> slave
>>>>>>>>> 20133 ywang25 20 0 106m 22m 4196 R 98 0.5 0:26.94 2
>>>>>>>>> slave
>>>>>>>>> 20129 ywang25 20 0 106m 22m 4176 R 100 0.5 0:28.45 3
>>>>>>>>> slave
>>>>>>>>> 20135 ywang25 20 0 106m 22m 4176 R 74 0.5 0:22.12 4
>>>>>>>>> slave
>>>>>>>>> 20134 ywang25 20 0 106m 24m 6708 R 98 0.6 0:27.73 5
>>>>>>>> master> 20128 ywang25 20 0 106m 22m 4180 R 90 0.5
>>>>>>>> 0:26.72 6 slave
>>>>>>>>> 20131 ywang25 20 0 106m 22m 4184 R 99 0.5 0:24.96 7
>>>>>>>>> slave
>>>>>>>>> 20133 ywang25 20 0 91440 5756 4852 R 87 0.1 0:44.20 0
>>>>>>>>> slave
>>>>>>>>> 20132 ywang25 20 0 91436 5764 4860 R 80 0.1 0:39.32 0
>>>>>>>> slave
>>>>>>>>> 20134
>>>>>>>>> ywang25 20 0 112m 36m 11m R 96 0.9 0:47.35 5 master
>>>>>>>>> 20129 ywang25 20 0 91440 5736 4832 R 91 0.1 0:46.84 1
>>>>>>>>> slave
>>>>>>>>> 20130 ywang25 20 0 91440 5748 4844 R 83 0.1 0:43.07 3
>>>>>>>>> slave
>>>>>>>>> 20131 ywang25 20 0 91432 5744 4840 R 84 0.1 0:41.20 4
>>>>>>>>> slave
>>>>>>>>> 20134 ywang25 20 0 112m 36m 11m R 96 0.9 0:47.35 5
>>>>>>>> master> 20128 ywang25 20 0 91432 5752 4844 R 93 0.1
>>>>>>>> 0:45.36 5 slave
>>>>>>>>> 20127 ywang25 20 0 91440 5724 4824 R 94 0.1 0:40.56 6
>>>>>>>>> slave
>>>>>>>>> 20135 ywang25 20 0 91440 5736 4832 R 92 0.1 0:39.75 7
>>>>>>>>> slave
