[MPICH] Availability of the Driller library
Jean-Marc Saffroy saffroy at gmail.com
Mon Sep 24 16:58:17 CDT 2007
Hi Darius,
Thanks for your feedback!
On Mon, 24 Sep 2007, Darius Buntinas wrote:
> The readme says that it does the switch atomically.  How do you make the
> copy from memory to the file atomic? You could have a situation when one
> thread is modifying memory while the other thread is performing the
> copy.  Do you handle this situation?
First, multiple threads are not handled at all in this code: the whole
thing is strange enough that I wanted to try it with single threaded
processes first, and this can already be useful. It may be possible to
handle multiple threads, but this will require a bit more thinking.
Signals are also an interesting problem, but probably easier to deal with
(I suspect it's mostly a matter of blocking all signals in some parts of
the Driller code).
I guess "atomic" was not the word I should have used here. What I meant to
say is that before and after the call to mmap that replaces an existing
memory region [*], the process can access this memory. Which is not the
whole truth, since a segment should not be modified after it has been
copied to a file and before it has been remapped; this means that read and
execute access can continue, but this is not as useful as I expected (I
disabled remapping of executable regions when I saw that it confused
oprofile, although it works fine).
[*] Note that this copy only occurs on memory segments that exist when
driller_init() is called; private anonymous segments requested after that
(typically by malloc) are immediately created inside memory-mapped files.
> Is there a way to split a vma and share only part of it?  That would be
> interesting as well.
Hmmm that would be possible, but the cost of sharing part or all of a
given memory region is roughly the same, so why would you want to do this?
Cheers,
