[MPICH] An idle communication process use the same CPU as computation process on multi-core chips
Bob Soliday soliday at aps.anl.gov
Fri Sep 14 12:11:16 CDT 2007
Sylvain Jeaugey wrote:
> That's unfortunate.
> Still, I did two programs. A master :
> int main() {
>         while (1) {
>             sched_yield();
>         return 0;
> and a slave :
> int main() {
>         while (1);
>         return 0;
> I launch 4 slaves and 1 master on a bi dual-core machine. Here is the
> result in top :
>   PID USER      PR  NI  VIRT  RES  SHR S %CPU %MEM    TIME+  COMMAND
> 12361 sylvain   25   0  2376  244  188 R  100  0.0   0:18.26 slave
> 12362 sylvain   25   0  2376  244  188 R  100  0.0   0:18.12 slave
> 12360 sylvain   25   0  2376  244  188 R  100  0.0   0:18.23 slave
> 12363 sylvain   25   0  2376  244  188 R  100  0.0   0:18.15 slave
> 12364 sylvain   20   0  2376  248  192 R    0  0.0   0:00.00 master
> 12365 sylvain   16   0  6280 1120  772 R    0  0.0   0:00.08 top
> If you are seeing 66% each, I guess that your master is not
> sched_yield'ing as much as expected. Maybe you should look at
> environment variables to force yield when no message is available, and
> maybe your master isn't so idle after all and has message to send
> continuously, thus not yield'ing.
On our FC5 nodes with 4 cores we get similar results. But on our FC7
nodes with 8 cores we don't. The kernel seems to think that all 9 jobs
require 100% and they end up jumping from one core to another. Often the
master job is left on it's own core while two slaves run on another.
   PID USER      PR  NI  VIRT  RES  SHR S %CPU %MEM    TIME+  P COMMAND
20127 ywang25   20   0  106m  22m 4168 R   68  0.5   0:06.84 0 slave
20131 ywang25   20   0  106m  22m 4184 R   73  0.5   0:07.26 1 slave
20133 ywang25   20   0  106m  22m 4196 R   75  0.5   0:07.49 2 slave
20129 ywang25   20   0  106m  22m 4176 R   84  0.5   0:08.44 3 slave
20135 ywang25   20   0  106m  22m 4176 R   73  0.5   0:07.29 4 slave
20132 ywang25   20   0  106m  22m 4188 R   70  0.5   0:07.04 4 slave
20128 ywang25   20   0  106m  22m 4180 R   78  0.5   0:07.79 5 slave
20130 ywang25   20   0  106m  22m 4180 R   74  0.5   0:07.45 6 slave
20134 ywang25   20   0  106m  24m 6708 R   80  0.6   0:07.98 7 master
20135 ywang25   20   0  106m  22m 4176 R   75  0.5   0:14.75 0 slave
20132 ywang25   20   0  106m  22m 4188 R   79  0.5   0:14.96 1 slave
20130 ywang25   20   0  106m  22m 4180 R   99  0.5   0:17.32 2 slave
20129 ywang25   20   0  106m  22m 4176 R  100  0.5   0:18.44 3 slave
20127 ywang25   20   0  106m  22m 4168 R   75  0.5   0:14.36 4 slave
20133 ywang25   20   0  106m  22m 4196 R   96  0.5   0:17.09 5 slave
20131 ywang25   20   0  106m  22m 4184 R   78  0.5   0:15.02 6 slave
20128 ywang25   20   0  106m  22m 4180 R   99  0.5   0:17.70 6 slave
20134 ywang25   20   0  106m  24m 6708 R  100  0.6   0:17.97 7 master
20130 ywang25   20   0  106m  22m 4180 R   87  0.5   0:25.99 0 slave
20132 ywang25   20   0  106m  22m 4188 R   79  0.5   0:22.83 0 slave
20127 ywang25   20   0  106m  22m 4168 R   75  0.5   0:21.89 1 slave
20133 ywang25   20   0  106m  22m 4196 R   98  0.5   0:26.94 2 slave
20129 ywang25   20   0  106m  22m 4176 R  100  0.5   0:28.45 3 slave
20135 ywang25   20   0  106m  22m 4176 R   74  0.5   0:22.12 4 slave
20134 ywang25   20   0  106m  24m 6708 R   98  0.6   0:27.73 5 master
20128 ywang25   20   0  106m  22m 4180 R   90  0.5   0:26.72 6 slave
20131 ywang25   20   0  106m  22m 4184 R   99  0.5   0:24.96 7 slave
20133 ywang25   20   0 91440 5756 4852 R   87  0.1   0:44.20 0 slave
20132 ywang25   20   0 91436 5764 4860 R   80  0.1   0:39.32 0 slave
                                                            20134
ywang25   20   0  112m  36m  11m R   96  0.9   0:47.35 5 master
20129 ywang25   20   0 91440 5736 4832 R   91  0.1   0:46.84 1 slave
20130 ywang25   20   0 91440 5748 4844 R   83  0.1   0:43.07 3 slave
20131 ywang25   20   0 91432 5744 4840 R   84  0.1   0:41.20 4 slave
20134 ywang25   20   0  112m  36m  11m R   96  0.9   0:47.35 5 master
20128 ywang25   20   0 91432 5752 4844 R   93  0.1   0:45.36 5 slave
20127 ywang25   20   0 91440 5724 4824 R   94  0.1   0:40.56 6 slave
20135 ywang25   20   0 91440 5736 4832 R   92  0.1   0:39.75 7 slave
