[MPICH] mpdboot error
jetspeed
ibatis2 at 163.com
Mon Sep 10 10:08:01 CDT 2007
Hi all,
I built OFED 1.2 on InfiniBand, with the Mvapich2-0.9.8,
when I run "mpd" on a node, it works. but when I run "mpdboot -n 1" It outputs as follow:
mpdboot_node01 (handle_mpd_output 359): failed to ping mpd on node01; recvd output={}
and in /tmp there isn't the mpd socket file, but a log file with the content:
logfile for mpd with pid 29122
node01_33226: mpd_uncaught_except_tb handling:
exceptions.TypeError: sequence item 0: expected string, int found
/usr/mpi/gcc/mvapich2-0.9.8-15/bin/mpdlib.py 733 handle_ring_listener_connection
newsock.correctChallengeResponse = \
/usr/mpi/gcc/mvapich2-0.9.8-15/bin/mpdlib.py 488 handle_active_streams
handler(stream,*args)
/usr/mpi/gcc/mvapich2-0.9.8-15/bin/mpd.py 266 runmainloop
rv = self.streamHandler.handle_active_streams(timeout=8.0)
/usr/mpi/gcc/mvapich2-0.9.8-15/bin/mpd.py 240 run
self.runmainloop()
/usr/mpi/gcc/mvapich2-0.9.8-15/bin/mpd.py 1344 ?
mpd.run()
any suggestions ?
thanks in advance.
