[MPICH] build MPICH2 on Windows
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Wed Oct 24 09:59:42 CDT 2007
 You can remove the ssm project from makewindist.bat without affecting the
compilation of other projects. Also if you are not planning to use MPE to
profile your applications you can also remove the "*P*" projects (eg:
ch3sockPRelease... ). You can remove the projects fortRelease, gfortRelease,
sfortRelease & fmpe from makewindist.bat if you do not need fortran specific
components. You can try building the source on a multi-core system to speed
things up.
 We had other users who built MPICH2 (1.0.6) on windows from the source
(When I built the windows binaries for MPICH2 I used the source provided in
the webpage.). Can you try building MPICH2 after removing the fortran
related projs from makewindist.bat and let us know the results ? It would be
great if you could also try running the extracterrmsgs script from command
line and let us know the results (Run "perl maint\extracterrmsgs
-skip=src\util/multichannel/mpi.c src\mpi src\nameserv src\util src\binding
src\include src\mpid src\pmi" from command line. Also try running the
extracterrmsgs script in debug mode as "perl maint\extracterrmsgs -debug
src\include src\mpid src\pmi".)
(Note: Also make sure that you modify the MPICH2 installer project to
reflect these changes -- i.e., no fortran libs, no MPE libs. We currently
have only one installer project and hence we have not removed/disentangled
the dependencies from makewindist.bat.)
Jayesh
  _____
Sent: Wednesday, October 24, 2007 2:28 AM
To: Jayesh Krishna
Subject: Re: [MPICH] build MPICH2 on Windows
Anyone has successfully build mpich2-1.0.6 on windows with the source
downloaded from the web?
I found the user guide is not so clear.
e.g. after running
winconfigure.wsf --remove-fortran --cleancode
(ps: the "could not open src\pmi" error is still there)
Is it necessary to remove fortran related project (fort/sfort/gfort/fpe)
from makewindist.bat?
I just want to compile the sock and shm channel, so can I remove the ssm
project?
The compiling is very very slow (it takes me more than 2 hours, and failed
at last), how to speed it up?
I want to know who built the MPICH2 binaries for windows on the web (the guy
in anl?), and maybe he/she is good at these questions.
Best
Andrew
On 10/24/07, Ruini Xue <xueruini at gmail.com> wrote:
On 10/23/07, Jayesh Krishna <jayesh at mcs.anl.gov  <mailto:jayesh at mcs.anl.gov>
> wrote:
 The "Unhandled definitions" is OK (These are definitions required for the
unix part of the code -- platform dependent). Do you have the "src\pmi"
directory in your source tree ? Can you try configuring without
"--remove-fortran" ?
I just downloaded the src from MPICH homepage, and the "src\pmi" folder is
right overthere. I have no fortran compiler so I want to remove it.
I try to configure it without "--remove-fortran", unfortunately, the error
is still there:
D:\Dev\mpich2-1.0.6>winconfigure.wsf --cleancode
Microsoft (R) Windows Script Host Version 5.6
Copyright (C) Microsoft Corporation 1996-2001. All rights reserved.
Creating src\include\win64\mpi.h
Creating src\include\win32\mpi.h
Creating src\include\win32\mpichtimer.h
Creating src\include\win64\mpichtimer.h
Creating src\include\mpich2info.h
Creating src\mpe2\src\logging\include\mpe_log_thread.h
Creating src\mpe2\src\callstack\include\mpe_callstack.h
Creating src\include\mpio.h
Creating src\mpi\romio\adio\include\romioconf.h
D:\Dev\mpich2-1.0.6\src\binding\cxx>perl buildiface -nosep
Creating src\include\mpicxx.h
modifying the comm, win datatype classes to handle unreferenced variables.
D:\Dev\mpich2-1.0.6\src\binding\f77>perl buildiface
Creating src\include\win32\mpif.h
Creating src\include\win64\mpif.h
Creating src\binding\f77\fprotos.h
Creating file: D:\Dev\mpich2-1.0.6\src\binding\f77\accumulatefs.c
Creating file: D:\Dev\mpich2-1.0.6\src\binding\f77\allgatherfs.c
Creating file: D:\Dev\mpich2-1.0.6\src\binding\f77\allgathervfs.c
Creating file: D:\Dev\mpich2-1.0.6\src\binding\f77\win_createfs.c
Creating src\binding\f77\setbotf.f
D:\Dev\mpich2-1.0.6\src\binding\f90>perl buildiface
D:\Dev\mpich2- 1.0.6>perl maint\extracterrmsgs
src\mpi src\nameserv src\util src\binding src\include src\mpid src\pmi
Could not open src\pmi
Because of errors in extracting error messages, the file
src\mpi\errhan\defmsg.h
 was not updated.
Creating maint\extractstates
Creating maint\extractstrings
D:\Dev\mpich2-1.0.6>perl maint\extractstates
Creating test\mpi\maint\testmerge
D:\Dev\mpich2-1.0.6\test\mpi\cxx\io>perl ..\..\maint\testmerge
-defn=..\..\maint
\common.defn ioharness.defn ioharness.tlt
D:\Dev\mpich2-1.0.6\test\mpi\f77\io >perl ..\..\maint\testmerge
-defn=..\..\maint
Creating src\include\win32\mpichconf.h
Creating src\include\win64\type1aint.h
Creating bin\mpicc.wsf
Creating winbuild directory
Creating src\pm\smpd\smpd_version.h: 1.0.6
Unhandled definitions:
HAVE_PVFS2_CREATE_WITHOUT_LAYOUT
HAVE_DLSYM
HAVE_F90_TYPE_ROUTINES
HAVE_PTHREAD_CLEANUP_PUSH
HAVE_PTHREAD_CLEANUP_PUSH_MACRO
LINUX86_CYCLE_CPUID_RDTSC
LINUX86_CYCLE_RDTSC
LINUX86_CYCLE_RDTSCP
MPICH2_LIBDIR
MPICH_DEBUG_MEMARENA
MPICH_DEBUG_MUTEX
USE_ALLOCA
USE_DYNAMIC_LIBRARIES
USE_NOPOSIX_FOR_IFCONF
Best
Andrew
Jayesh
  _____
<mailto:owner-mpich-discuss at mcs.anl.gov> owner-mpich-discuss at mcs.anl.gov] On
Behalf Of Ruini Xue
Sent: Tuesday, October 23, 2007 9:00 AM
Subject: [MPICH] build MPICH2 on Windows
Hello,
I download the src of MPICH2-1.0.6 and followed the user guide to build it:
G:\mpich2-1.0.6>winconfigure.wsf --remove-fortran --cleancode
Copyright Reserved (C) Microsoft Corporation 1996-2001.
G:\mpich2-1.0.6\src\binding\cxx>perl buildiface -nosep
G:\mpich2-1.0.6>perl maint\extracterrmsgs -skip=src\util/multichannel/mpi.c
src\
 was not updated.
G:\mpich2-1.0.6>perl maint\extractstates
G:\mpich2-1.0.6\test\mpi\cxx\io>perl ..\..\maint\testmerge
-defn=..\..\maint\com
G:\mpich2-1.0.6\test\mpi\f77\io>perl ..\..\maint\testmerge
Creating src\include\win64\mpichconf.h
Creating src\include\win64\mpe_logging_conf.h
Creating src\include\win32\mpe_wrappers_conf.h
Creating src\include\win64\mpe_wrappers_conf.h
HAVE_DLSYM
LINUX86_CYCLE_RDTSC
MPICH2_LIBDIR
MPICH_DEBUG_MUTEX
USE_ALLOCA
HAVE_GCC_ASM_SPARC_MEMBAR
HAVE_GCC_ASM_SPARC_STBAR
HAVE_SOLARIS_ASM_SPARC_MEMBAR
HAVE_SOLARIS_ASM_SPARC_STBAR
GCC_X86_CYCLE_CPUID_RDTSC
GCC_X86_CYCLE_RDTSC
GCC_X86_CYCLE_RDTSCP
HAVE_LIBPTHREAD
HAVE_MPI_INIT_THREAD
HAVE_EXECINFO_H
HAVE_FDOPEN
HAVE_UCONTEXT_H
NEEDS_FDOPEN_DECL
HAVE_H_ADDR_LIST
ERROR: 28 definitions not handled
(61 instances of unhandled definitions)
Why it complains "could not open src\pmi"?
Best
Andrew
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20071024/be047aa7/attachment.htm>
