[MPICH] MPICH2 and Pascal
Lourival Mendes
mendes.lourival at gmail.com
Sun Oct 21 16:41:53 CDT 2007
Dear Luiz and Lykle,
Lykle: I'm afraid that turbo pascal 7 is quite older now. I'm using the
Lazarus (which is the Visual of the Free Pascal Compiler - like Delphi), I
usually works with FPC and Delphi also.
The program is developed for both Linux and Windows (once compiled on
each SO). I agree with you when you say that the trick is to call the
mpi-routines, written in C, from Pascal. I tried to do this, but the headers
have links to the LIB files and I can't read from the Pascal.
Luiz: I don't know pretty much Fortran, specially I don't know the
OpenWatcom. As far as I know the MPICH2 has some Fortran files that you
should link on your compiler. The problem is that not all the compiler can
make the compile on the right way.
I do believe that you are right the problem concerns the suffix and
prefix of the calling functions, maybe you should think about to create some
files from other fortran compile that is used on the MPICH2 files... but I
don't know which is because I don't know pretty much about fortran
languages...
Hugs
Lourival
Are you developing for Windows or Linux? Which Pacal
2007/10/21, Luiz Carlos da Costa Junior <lcjunior at ufrj.br>:
> Lykle and Lourival,
> Let me introduce myself and participate in this discussion (actually add
> another question). My name is Luiz and I have a problem like Lourival. I
> would like to use MPICH2 with my fortran program (developed for Windows and
> compiled with OpenWatcom 1.3) but I had problems during the linking
> process.
> I have a little experience in using C libraries in my fortran programs and
> I use to recompile the libraries header (generating *.lib file that I can
> use in OW1.3 linking process) but in case of MPI I didn't have success
> because of functions name (my liker doesn't not recognize MPI functions).
> Maybe because of naming convention, prefix/sufix additions. How is the best
> way to deal with it?
> Another problem I had is due to the type "long long", used in MPICH2.
> Unfortunately, OpenWatcom 1.3 doesn't seen to support it (I can be wrong),
> do you known how to deal with this problem?
> Thanks in advance!
> Luiz
> On 10/21/07, Lykle Voort < lyklevoort at gmail.com> wrote:
> > My experience with Pascal goes back to turbo pascal version 7, I am
> > afraid, but I have quite a bit of experience with calling c routines from
> > fortran on windows and linux.
> > The trick is to call a the mpi-routines, written in C, from Pascal. The
> > difficulty is usually to get the arguments and the function names right; the
> > linker takes care of the rest.
> > Are you developing for Windows or Linux? Which Pacal compiler do you
> > use?
> > Lykle Voort
> > On 10/21/07, Lourival Mendes < mendes.lourival at gmail.com> wrote:
> > > Hy everybody, as probably you saw before, I'm trying to use the
> > > MPICH2 on the Pascal environment. I try to find something on the net but
> > > with almost no success.
> > > Does anybody has an advice from where I should start?? Should I
> > > convert the headers and lib files from the standard installation or should I
> > > use the source code?? What is the best way?? How it works for the fortran
> > > code??
> > > Thanks in advance..
> > > Lourival J. Mendes Neto
> > Lykle Voort
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20071021/1ddfd814/attachment.htm>
