[MPICH] libmpich.a incompatible
    Anthony Chan
    chan at mcs.anl.gov
    Thu Oct 11 13:30:19 CDT 2007
What is the command you used to compile pi3f90.f90 ?
On Thu, 11 Oct 2007, Venkattraman A wrote:
> Hi,
>    I was trying to compile the example programmes(the f90 file pi3f90.f90)
> in mpich2-1.0.6 and I got an error message
> ld: skipping incompatible /home/xguo/Desktop/mpich2-1.0.6/lib/libmpich.a
> when searching for -lmpich
> ld: skipping incompatible /usr/local/lib/libmpich.a when searching for
> -lmpich
> ld: cannot find -lmpich
> However the corresponding example in cxx works fine. I got the same problem
> with the earlier versions also(2-1.0.5 and 2-1.0.4). I work with Mandriva
> Linux and the processor is a 64 bit AMD.
> Any suggestions?
> Venkattraman
