[MPICH] [MPICH2] drivemap problem - won't finalize properly?
Jayesh Krishna
jayesh at mcs.anl.gov
Tue Oct 9 14:56:38 CDT 2007
I can recreate the problem here. I will look into the problem and get back
to you.
Jayesh
_____
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Lykle Voort
Sent: Tuesday, October 09, 2007 12:05 PM
Subject: [MPICH] [MPICH2] drivemap problem - won't finalize properly?
I have a very annoying problem with all recent versions of MPICH2 (up to
1.0.6). It seems like the drive map's don't get finalized properly.
The problem can be reproduced by using any mpich2 program and using a drive
map. WIth the "net session" command, the active sessions can be displayed.
Every time the mpich2 program is run, the number of sessions in "net
session" increases. The problem starts when the number of sessions has
reached a certain limit, usually within 6 or so runs. This works even for
all programs, so if you want to test it, use a simple program.
When I run "smpd" in debug mode ("smpd -debug"), smpd keeps giving access
violations.
Does anyone have simular problems?
Does anyone have a solution? A patch?
Lykle Voort
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20071009/f3e6f415/attachment.htm>
