[MPICH] Can I ask MPI to not copy the data to shared-mem ?
    chong tan
    chong_guan_tan at yahoo.com
    Tue Oct  9 11:53:20 CDT 2007
Well, shared-mem and sending 0 byte does not work if the processes are on differnt boxes.  My thought is that since MPICH already make the dicission on wheter to use shared memory.  It is a nature fit that the 'no copy' rule be applied in that domain.
  thanks
  tan
Darius Buntinas <buntinas at mcs.anl.gov> wrote:
On 10/08/2007 01:38 PM, chong tan wrote:
> I am interested in the case that the send and recieve buffer are the
> same buffer allocated from shared-memory, in which case there is no need
> for the data copying, send and recieve just only do the sync.
In this case, why not use a zero-byte message? The sender fills in the
shared buffer, does a write barrier, then calls MPI_Send with a
zero-byte message. The receiver calls MPI_Recv, to receive zero bytes,
then when it returns, it does a read barrier and reads the data from the
shared buffer.
> A side question, when MPI_Send is called, does MPICH copy the data into
> a intermediate global buffer ? and have the data copy from this same
> buffer on MPI_Recv call ?
It depends on the channel and what you're sending. For non-contiguous
data, the data may be packed into a contiguous buffer before sending and
unpacked from a contiguous buffer when receiving. Otherwise, if a
channel uses sockets, an intermediate buffer is not used by MPICH2, but
the OS will perform intermediate copies. For a channel that uses a
high-performance network, an intermediate buffer is used for small
messages, but for large messages the data is transferred directly from
or into the user's buffer.
-d
> tan
> */Darius Buntinas /* wrote:
> Well, you specify one buffer in the call to MPI_Send and another buffer
> in MPI_Recv, so there would have to be at least one copy. You can't do
> it without any copies (otherwise, how would the data get from the send
> buffer to the receive buffer?).
> MPICH2 does support communication over shared memory (as opposed to
> over
> a network) which improves performance for intranode communication.
> Configure with --with-device=ch3:ssm or --with-device=ch3:nemesis.
> Darius
> On 10/08/2007 12:22 PM, chong tan wrote:
> > If I the pointer passed to MPI_Send and MPI_Recieve are already
> shared
> > memory, and need not be copied at all ?
> > If so, How ?
> > thanks
> > tan
> > Be a better Heartthrob. Get better relationship answers
> > from
> > someone who knows.
> > Yahoo! Answers - Check it out.
> Need a vacation? Get great deals to amazing places
> on
> Yahoo! Travel.
Boardwalk for $500? In 2007? Ha!
Play Monopoly Here and Now (it's updated for today's economy) at Yahoo! Games.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20071009/a0d96167/attachment.htm>
