[MPICH] Running on root's MPD as either root or another user
Matt Chambers
matthew.chambers at vanderbilt.edu
Mon Oct 1 20:14:24 CDT 2007
I don't understand how getting an MPD running from a user account will
help me in debugging why I can't get my user account to use root's
existing MPD ring. To clarify, root's MPD ring works perfectly fine and
I can run MPI programs as root over any number of nodes. It's only when
I try to use root's ring from a user account that the multi-node mpiexec
calls hang (apparently while trying to get a socket, or at least that's
the error it gives when breaking at the hang).
-Matt
Ralph Butler wrote:
> Yes, if it all works in side one machine, then the problem is almost
> certainly due to host/net config
> issues. The manual actually suggests not trying things as root until
> you have all those issues
> addressed. Those problems are addressed via running mpdcheck.
> Here is a blurb about that:
> Sometimes there are problems with mpd or mpdboot while following
> the Quick Start portion of the mpich2 install guide. This typically
> happens somewhere during Steps 10-13, but may occur during other
> steps as well. The guide suggests that when mpd/mpdboot problems
> arise, you follow the procedures in Appendix A (Troubleshooting MPDs).
> Section A.1 (Getting Started with MPD) provides a 7-step procedure
> to follow to get one or more mpds to working, first by hand, and
> then via mpdboot. However, some of the early steps begin with a
> pre-MPD program called mpdcheck. That program is designed to help
> determine in advance if there will be problems associated wtih host
> or network configuration. The instructions in section A.1 suggest
> first using mpdcheck on individual machines, and then pair-wise.
> It is particularly important to try the pair-wise experiments where
> one machine plays the role of the server and the other the client,
> and then to reverse the roles.
> Sometimes the procedures in A.1 indicate that MPDs are not likely
> to run on your systems due to problems with host and/or network
> configuration. At those points, you are referred to subsequent
> sections, e.g. A.2 Debugging host/network configuration problems,
> or A.3 Firewalls, etc.
