[MPICH] MPI_FUNDAMENTAL no longer defined in mpich2?
Anthony Chan
chan at mcs.anl.gov
Wed Nov 28 13:07:35 CST 2007
On Wed, 28 Nov 2007, David Gunter wrote:
> I have a piece of test code that contains the following:
> MPI_Type_get_envelope(MPI_INT, &num_ints, &num_addrs, &num_types,
> &combiner);
> if (combiner != MPI_FUNDAMENTAL) {
> testflag=1;
> fprintf(stderr, "[%d] error, combiner is %d, should be %d\n", myid,
> combiner, 0);
I did a google search of MPI_FUNDAMENTAL on www.mpi-forum.org and I didn't
see it mentioned in the standard except on couple archived emails. So
I don't think MPI_FUNDAMENTAL is in the standard. (BTW, I couldn't
find MPI_FUNDAMENTAL defined in the mpi.h in the latest MPICH2, MPICH1 and
OpenMPI)
Could you use MPI_COMMBINER_NAMED instead MPI_FUNDAMENTAL ? see
http://www.mpi-forum.org/docs/mpi-20-html/node161.htm
A.Chan
> I get an error message when trying to compile that MPI_FUNDAMENTAL has not
> been defined. In looking through the various mpi include files, I see that
> is the case - there is no mention of it anywhere.
> Has MPI_FUNDAMENTAL been dropped in MPI-2?
> Thanks,
> david
> David Gunter
> HPC-3: Parallel Tools Team
