[MPICH] RE: Visual studio 2003 with MPI
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Fri Nov 16 10:18:02 CST 2007
 Looks to me that export_flush() is a function written by the programmer (it
is not an MPI func) to flush/cleanup the exported graph co-ordinates.
Jayesh
  _____
From: Bhaskar Subramanian [mailto:bhaskar_17 at yahoo.com]
Sent: Thursday, November 15, 2007 7:05 PM
To: Jayesh Krishna
Subject: RE: Visual studio 2003 with MPI
hi jayesh,
I am doing a research on MPI implementation of minimal spanning tree. I
found an implementation of minimal spanning tree for MPI
http://answers.google.com/answers/threadview?id=503278
but when i try to run , i am getting an error in this place
"export_flush(1,index,4,taken); " also i noted that this C file has been
commented out //#include <\mpi\mpi2m.c>. Just wanted to ask if its in the
previous of mpi or is it the file the user wrote ?
also can u confirm that these statements
      export_flush(1,index,4,graph);
      export_flush(2,&index[1],6,nodes);
the function export_flush is inbuilt in mpi ?
if this is wrong, do you know any place where i could get the code for this
mininmal spanning tree using MPI (C/C++) ? i really need this to get my
research done.
Thank you
bhaskar
Jayesh Krishna <jayesh at mcs.anl.gov> wrote:
 Great! Let us know if you need any further assistance.
Jayesh
  _____
Sent: Thursday, August 09, 2007 12:30 PM
To: Jayesh Krishna
hi jayesh,
Thank you for your prompt reply, as you were talking about process manager,
i went to services and checked it. It was disabled. so i had to enable and
restart my computer and now it works like a charm.
I really thank you for your help and prompt reply
Thank you
bhaskar
 The error message says that the mpiexec command was not able to connect to
the process manager.
 Did your MPICH2 installation complete successfully ? Have you added the
MPICH2 bin directory to your PATH ?
 Please let us know the following info,
1) What is the status of the smpd process manager (type "smpd -status" at
command prompt for the status of smpd)
2) Can you run the sample application, cpi.exe, provided with the
installation ? (type "mpiexec -n 2 cpi.exe" for running cpi.exe)
3) Do you have any other version of MPICH installed on your machine ?
Jayesh
  _____
Sent: Wednesday, August 08, 2007 7:23 PM
To: jayesh at mcs.anl.gov
Subject: Reg:Visual studio 2003 with MPI
hi jayesh,
This is bhaskar, actually i am trying to run MPI in visual studio 2003
(stand alone) in sense, i want to compile and run MPI program in VS 2003
without only one computer (running processes for each processor).
I installed MPICH2, i disabled my firewall, i also did add the necessary
libraires as per this doc...
MPICH2
<http://www-unix.mcs.anl.gov/mpi/mpich2/downloads/mpich2-doc-windev.pdf>
Windows Development Guide.
but i am getting the following error, do u have any idea as to what this is
and how can i rectify this ?
Much appreciate your help
Thank you
bhaskar
ERROR:
C:\vs projects\vc++ projs\Parallelcomp>cd debug
C:\vs projects\vc++ projs\Parallelcomp\Debug>mpiexec -n 2 Parallelcomp
Unable to connect to 'bhaskar:8676',
sock error: generic socket failure, error stack:
MPIDU_Sock_post_connect(1228): unable to connect to bhaskar on port 8676,
exhausted al
l endpoints (errno -1)
MPIDU_Sock_post_connect(1275): unable to connect to bhaskar on port 8676, No
connectio
n could be made because the target machine actively refused it. (errno
10061)
  _____
Luggage? GPS? Comic books?
Check out fitting gifts
<http://us.rd.yahoo.com/evt=48249/*http://search.yahoo.com/search?fr=oni_on_
mail&p=graduation+gifts&cs=bz> for grads at Yahoo! Search.
  _____
Yahoo! oneSearch: Finally, mobile
<http://us.rd.yahoo.com/evt=48252/*http://mobile.yahoo.com/mobileweb/onesear
ch?refer=1ONXIC> search that gives answers, not web links.
  _____
Be a better sports nut! Let your teams follow you with Yahoo Mobile. Try
<http://us.rd.yahoo.com/evt=51731/*http://mobile.yahoo.com/sports;_ylt=At9_q
DKvtAbMuh1G1SQtBI7ntAcJ> it now.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20071116/2217d97c/attachment.htm>
