[MPICH] a question about MPI - Pblm in Publish/Lookup with SMPD
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Wed Nov  7 14:36:33 CST 2007
 We are looking into the problem (The problem is not in your code. It is a
bug in the SMPD process manager.). Meanwhile, as a workaround, try putting a
barrier after publish and before lookup and run the programs as below,
      mpiexec -n 1 LookupClient.exe : -n 1 PublishServer.exe
 The excerpt from the modified files are given below for your reference,
############# LookupClient.c #######################
int main(..){
MPI_Get_processor_name(processor_name,&namelen);
MPI_Barrier(MPI_COMM_WORLD);
MPI_Lookup_name(serv_name, MPI_INFO_NULL, port_name_out );
############# PublishServer.c #######################
int main(...){
MPI_Open_port(MPI_INFO_NULL, port);
printf("opened port...<%s>\n", port);
fflush(stdout);
merr = MPI_Publish_name( serv_name, MPI_INFO_NULL, port );
 Let us know if it works for you.
Jayesh
  _____
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of menglige
Sent: Tuesday, November 06, 2007 7:12 PM
To: mpich-discuss
Subject: [MPICH] a question about MPI
HELLO!
    i hava two '.exe' ,and i want to send message from one to the other.
i use 'mpiexec' to run send.exe
and then use 'mpiexec' to run receive.exe,
but there is an erro ,receive.exe can find the published port .what 's wrong
with me ??? (i hava attached my code).
THANK YOU VERY MUCH
  _____
menglige
2007-11-06
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20071107/847241d1/attachment.htm>
Name: not available
Type: image/gif
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20071107/847241d1/attachment.gif>
