[MPICH] MPICH2 on Windows XP Pro Network
    AGPX
    agpxnet at yahoo.it
    Thu Nov  1 13:08:34 CDT 2007
Hi all,
I have installed the latest version of MPICH2 on two machines on my local network.
Both machines have Windows XP Pro SP2 installed and there aren't firewall actived.
Both machines have the same user account (with Administrator priviledge): AGPX, with the same password.
Both machines have the same phrase for the smpd.
Both machines are in the workgroup named: WORKGROUP
Name of the machine are: pcamd3000 and pcamd2600
On pcamd3000 I do the following:
mpiexec -register
I have specified WORKGROUP\pcamd3000 and the password used for the user account AGPX
On pcamd2600 I do the following:
mpiexec -register
I have specified WORKGROUP\pcamd2600 and the password used for the user account AGPX
Then I have tried:
On pcamd3000:
smpd -status
smpd running on pcamd3000
On pcamd2600:
smpd -status
smpd running on pcamd2600
Well done. Next step (from c:\program files\mpich2\examples):
On pcamd3000:
mpiexec -hosts 1 pcamd3000 cpi.exe
Enter the number of intervals:  (0 quits) 0
On pcamd2600:
mpiexec -hosts 1 pcamd2600 cpi.exe
But If I try:
On pcamd3000:
mpiexec -hosts 2 pcamd3000 pcamd2600 cpi.exe
I obtain:
abort: unable to connect to pcamd2600
On pcamd2600:
I obtain:
abort: unable to connect to pcamd3000
Both machines see each other (via ping). To verify better I do (on pcamd3000):
telnet pcamd2600 8676
the response was:
1.0.6 292
so basically, I can connect to smpd of pcamd2600.
I try on pcamd3000:
mpiexec -verbose -hosts 2 pcamd3000 pcamd2600 cpi.exe
here the full response:
..\smpd_add_host_to_default_list
...\smpd_add_extended_host_to_default_list
.../smpd_add_extended_host_to_default_list
../smpd_add_host_to_default_list
..\smpd_get_full_path_name
...fixing up exe name: 'cpi.exe' -> '(null)'
../smpd_get_full_path_name
..handling executable:
cpi.exe
..\smpd_get_next_host
...\smpd_get_host_id
.../smpd_get_host_id
../smpd_get_next_host
..\smpd_create_cliques
...\prev_launch_node
.../prev_launch_node
../smpd_create_cliques
..\smpd_fix_up_host_tree
../smpd_fix_up_host_tree
./mp_parse_command_args
.host tree:
. host: pcamd3000, parent: 0, id: 1
. host: pcamd2600, parent: 1, id: 2
.launch nodes:
. iproc: 1, id: 2, exe: cpi.exe
. iproc: 0, id: 1, exe: cpi.exe
.\smpd_create_context
..\smpd_init_context
...\smpd_init_command
.../smpd_init_command
../smpd_init_context
./smpd_create_context
.\smpd_make_socket_loop
..\smpd_get_hostname
../smpd_get_hostname
./smpd_make_socket_loop
.\smpd_enter_at_state
..sock_waiting for the next event.
..SOCK_OP_CONNECT
..\smpd_handle_op_connect
...connect succeeded, posting read of the challenge string
../smpd_handle_op_connect
..SOCK_OP_READ
..\smpd_handle_op_read
...\smpd_state_reading_challenge_string
....read challenge string: '1.0.6 9961'
....\smpd_verify_version
..../smpd_verify_version
....\smpd_hash
..../smpd_hash
.../smpd_state_reading_challenge_string
../smpd_handle_op_read
..SOCK_OP_WRITE
..\smpd_handle_op_write
...\smpd_state_writing_challenge_response
....wrote challenge response: 'a0256a5646a163e279c8db9db9042b15'
.../smpd_state_writing_challenge_response
../smpd_handle_op_write
..SOCK_OP_READ
...\smpd_state_reading_connect_result
....read connect result: 'SUCCESS'
.../smpd_state_reading_connect_result
..SOCK_OP_WRITE
...\smpd_state_writing_process_session_request
....wrote process session request: 'process'
.../smpd_state_writing_process_session_request
..SOCK_OP_READ
...\smpd_state_reading_cred_request
....read cred request: 'credentials'
....\smpd_hide_string_arg
.....\first_token
...../first_token
.....\compare_token
...../compare_token
.....\next_token
......\first_token
....../first_token
......\first_token
....../first_token
...../next_token
..../smpd_hide_string_arg
.....\first_token
...../first_token
.....\compare_token
...../compare_token
.....\next_token
......\first_token
....../first_token
......\first_token
....../first_token
...../next_token
.....\first_token
...../first_token
.....\compare_token
...../compare_token
.....\next_token
......\first_token
....../first_token
......\first_token
....../first_token
...../next_token
.....\smpd_option_on
......\smpd_get_smpd_data
.......\smpd_get_smpd_data_from_environment
......./smpd_get_smpd_data_from_environment
.......\smpd_get_smpd_data_default
......./smpd_get_smpd_data_default
.......Unable to get the data for the key 'nocache'
...../smpd_option_on
.....\first_token
...../first_token
.....\compare_token
...../compare_token
.....\next_token
......\first_token
....../first_token
......\first_token
....../first_token
...../next_token
.../smpd_handle_op_read
...sock_waiting for the next event.
...SOCK_OP_WRITE
...\smpd_handle_op_write
....\smpd_state_writing_cred_ack_yes
.....wrote cred request yes ack.
..../smpd_state_writing_cred_ack_yes
.../smpd_handle_op_write
...SOCK_OP_WRITE
....\smpd_state_writing_account
.....wrote account: 'WORKGROUP\AGPX'
.....\smpd_encrypt_data
...../smpd_encrypt_data
..../smpd_state_writing_account
...SOCK_OP_WRITE
.....\first_token
...../first_token
.....\compare_token
...../compare_token
.....\next_token
......\first_token
....../first_token
......\first_token
....../first_token
...../next_token
.....\smpd_hide_string_arg
......\first_token
....../first_token
......\compare_token
....../compare_token
......\next_token
.......\first_token
......./first_token
.......\first_token
......./first_token
....../next_token
...../smpd_hide_string_arg
.....\first_token
...../first_token
.....\compare_token
...../compare_token
.....\next_token
......\first_token
....../first_token
......\first_token
....../first_token
...../next_token
...SOCK_OP_READ
...\smpd_handle_op_read
....\smpd_state_reading_process_result
.....read process session result: 'SUCCESS'
..../smpd_state_reading_process_result
...SOCK_OP_READ
....\smpd_state_reading_reconnect_request
.....read re-connect request: '1037'
.....closing the old socket in the left context.
.....MPIDU_Sock_post_close(1724)
.....connecting a new socket.
.....\smpd_create_context
......\smpd_init_context
.......\smpd_init_command
......./smpd_init_command
....../smpd_init_context
...../smpd_create_context
.....posting a re-connect to pcamd3000:1037 in left context.
..../smpd_state_reading_reconnect_request
...SOCK_OP_CONNECT
...\smpd_handle_op_connect
....\smpd_generate_session_header
.....session header: (id=1 parent=0 level=0)
..../smpd_generate_session_header
.../smpd_handle_op_connect
...SOCK_OP_WRITE
....\smpd_state_writing_session_header
.....wrote session header: 'id=1 parent=0 level=0'
.....\smpd_post_read_command
......posting a read for a command header on the left context, sock 1660
...../smpd_post_read_command
.....creating connect command for left node
.....creating connect command to 'pcamd2600'
.....\smpd_create_command
...../smpd_create_command
.....\smpd_add_command_arg
...../smpd_add_command_arg
.....\smpd_add_command_int_arg
...../smpd_add_command_int_arg
.....\smpd_post_write_command
......\smpd_package_command
....../smpd_package_command
......smpd_post_write_command on the left context sock 1660: 65 bytes for command: "cmd=connect src=0 dest=1 tag=0 host=pcamd2600 id=2 "
...../smpd_post_write_command
.....not connected yet: pcamd2600 not connected
..../smpd_state_writing_session_header
...SOCK_OP_CLOSE
...\smpd_handle_op_close
....\smpd_get_state_string
..../smpd_get_state_string
....op_close received - SMPD_CLOSING state.
....Unaffiliated left context closing.
....\smpd_free_context
.....freeing left context.
..../smpd_free_context
.../smpd_handle_op_close
...SOCK_OP_WRITE
....\smpd_state_writing_cmd
.....wrote command
.....command written to left: "cmd=connect src=0 dest=1 tag=0 host=pcamd2600 id=2 "
.....moving 'connect' command to the wait_list.
..../smpd_state_writing_cmd
...SOCK_OP_READ
....\smpd_state_reading_cmd_header
.....read command header
.....command header read, posting read for data: 69 bytes
..../smpd_state_reading_cmd_header
...SOCK_OP_READ
.....read command
.....\smpd_parse_command
...../smpd_parse_command
.....read command: "cmd=abort src=1 dest=0 tag=0 error="unable to connect to pcamd2600" "
.....\smpd_handle_command
......handling command:
...... src  = 1
...... dest = 0
...... cmd  = abort
...... tag  = 0
...... ctx  = left
...... len  = 69
...... str  = cmd=abort src=1 dest=0 tag=0 error="unable to connect to pcamd2600"
......\smpd_command_destination
.......0 -> 0 : returning NULL context
....../smpd_command_destination
......\smpd_handle_abort_command
.......abort: unable to connect to pcamd2600
....../smpd_handle_abort_command
...../smpd_handle_command
......smpd_post_write_command on the left context sock 1660: 43 bytes for command: "cmd=close src=0 dest=1 tag=1 "
...SOCK_OP_WRITE
.....wrote command
.....command written to left: "cmd=close src=0 dest=1 tag=1 "
.....\smpd_free_command
...../smpd_free_command
...SOCK_OP_READ
.....command header read, posting read for data: 31 bytes
...SOCK_OP_READ
.....read command
.....read command: "cmd=closed src=1 dest=0 tag=1 "
...... src  = 1
...... dest = 0
...... cmd  = closed
...... tag  = 1
...... ctx  = left
...... len  = 31
...... str  = cmd=closed src=1 dest=0 tag=1
......\smpd_handle_closed_command
.......closed command received from left child, closing sock.
.......MPIDU_Sock_post_close(1660)
.......received a closed at node with no parent context, assuming root, returning SMPD_EXITING.
....../smpd_handle_closed_command
.....not posting read for another command because SMPD_EXITING returned
...SOCK_OP_CLOSE
....op_close received - SMPD_EXITING state.
../smpd_enter_at_state
./main
.\smpd_exit
..\smpd_kill_all_processes
../smpd_kill_all_processes
..\smpd_finalize_drive_maps
../smpd_finalize_drive_maps
..\smpd_dbs_finalize
../smpd_dbs_finalize
What's wrong? Seems that authentication doesn't work.
I haven't share any directory and on pcamd3000, windows is located on C:\Windows. On pcamd2600, windows is located on E:\Windows. Can this be a problem?
I tried also on pcamd3000:
smpd -status pcamd2600
Aborting: unable to connect to pcamd2600
All this test give the same results when launched on pcamd2600.
I found no clue in the previous message of this mailing list. I really doesn't understand what is going wrong. Please help me!
Gianluca Arcidiacono
      ___________________________________
L'email della prossima generazione? Puoi averla con la nuova Yahoo! Mail: http://it.docs.yahoo.com/nowyoucan.html
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20071101/d615dae6/attachment.htm>
