[MPICH] debug flag
    Rajeev Thakur
    thakur at mcs.anl.gov
    Wed May 30 13:05:03 CDT 2007
> I have written a short C code for this I/O pattern. ...
> Let me know if you would like a copy of it.
Of course!
> -----Original Message-----
> From: Wei-keng Liao [mailto:wkliao at ece.northwestern.edu]
> Sent: Wednesday, May 30, 2007 11:49 AM
> To: Rajeev Thakur
> Cc: mpich-discuss at mcs.anl.gov
> Subject: RE: [MPICH] debug flag
> I just got the results by disabling aggregation. The coredump was
> generated by rank 784 (out of 4000) and indicates the following info.
> ad_aggregate.c:242
>      proc = -603978814     <-- !?
>      off = -166212992      <-- !?
>      min_st_offset = 0
>      fd_len = 400
>      fd_size = 262582  <-- should be 11000000
> going up one level to ad_write_coll.c:170
>      below is some of variables set by
> ADIOI_Calc_my_off_len() at line 101
>      count 1375000
>      offset = 0
>      start_offset = 407601600
>      end_offset = -2149678961    <-- should be 839993999
>      contig_access_count = 27500
> I suspect the file type is not flatten correctly.
> I have written a short C code for this I/O pattern. I ran it on 4000
> processes and it produced the same error. On 2000 processes, it ran
> fine, just like my program. Let me know if you would like a
> copy of it.
> Wei-keng
> On Tue, 29 May 2007, Rajeev Thakur wrote:
> > Can you try disabling aggregation and see if the error
> still remains. You
> > can disable it by creating an info object as follows and
> passing it to
> > File_set_view
> >     MPI_Info_set(info, "cb_config_list", "*:*");
> > Rajeev
> >> From: owner-mpich-discuss at mcs.anl.gov
> >> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Wei-keng Liao
> >> Sent: Tuesday, May 29, 2007 1:33 AM
> >> To: Howard Pritchard
> >> Subject: Re: [MPICH] debug flag
> >> Howard,
> >> Thanks for this information. It is very helpful. I was able
> >> to find more
> >> details by using the debug built mpich. Below is what I found
> >> from the
> >> coredump that may help debugging the ROMIO source.
> >> 1. coredump is from MPI rank 2919. I allocated 4000 MPI processes,
> >>     (2000 nodes, each nodes has 2 CPUs). I am checking
> >> mpich2-1.0.2 source.
> >> 2. MPI_Abort() is called at line 97 by function
> >> ADIOI_Calc_aggregator(),
> >>     in file ad_aggregate.c where
> >>     rank_index = 5335, fd->hints->cb_nodes = 2000, off =
> 2802007600,
> >>     min_off = 0, fd_size = 525164 (fd_size should be 11000000))
> >> 3. It is function ADIOI_Calc_my_req() called
> >> ADIOI_Calc_aggregator() at
> >>     line 240, from file ad_aggregate.c, where
> >>     i = 0 in loop    for (i=0; i < contig_access_count; i++)
> >>     off = 2802007600, min_st_offset = 0, fd_len = 400,
> >> fd_size = 525164
> >> 4. It is function ADIOI_GEN_WriteStridedColl() called
> >> ADIOI_Calc_my_req()
> >>     at line 170, from file ad_write_coll.c
> >>     I would like to see what went wrong with fd_size from function
> >>     ADIOI_Calc_file_domains() where fd_size is set and saw
> >> that fd_size is
> >>     determined by st_offsets[] and end_offsets[] which depend
> >> on variables
> >>     start_offset and end_offset.
> >>     So, I went a few line up and checked the values for variables
> >>     start_offset and end_offset. They were set by
> >>     at line 101 and I found the value of end_offset must be wrong!
> >>     end_offset should always >= start_offset, but the core
> shows that
> >>         start_offset = 2802007600, end_offset = 244727039
> >>     So, I looked into ADIOI_Calc_my_off_len() in
> >> ad_read_coll.c and checked
> >>     variable end_offset_ptr which was set by variable
> >> end_offset at line
> >>     453, since filetype_size > 0 and filetype_is_contig == 0.
> >>     Hence, the only place end_offset is set is at line 420:
> >>         end_offset = off + frd_size - 1;
> >>     end_offset is determined by off and frd_size. However, frd_size
> >>     is declared as an integer. But end_offset is ADIO_Offset. Maybe
> >>     it is an type overflow! At line 351, I can see a type cast
> >>         frd_size = (int) (disp + flat_file->indices[i] + ...
> >>     Something fishy here. Unfortunately, the coredump does
> >> not cover here.
> >>     Look like an interactive debugging with a break point
> >> cannot be avoided.
> >> Wei-keng
> >> On Mon, 28 May 2007, Howard Pritchard wrote:
> >>> Hello Wei-keng,
> >>> Here is a way on xt/qk systems to compile with the debug
> >> mpich2 library:
> >>> 1) do
> >>>   module show xt-mpt
> >>>   to see which mpich2 the system manager has made the default.
> >>>   For instance, on an internal system here at cray this
> >> command shows:
> >>> /opt/modulefiles/xt-mpt/1.5.49:
> >>> setenv           MPT_DIR /opt/xt-mpt/1.5.49
> >>> setenv           MPICHBASEDIR /opt/xt-mpt/1.5.49/mpich2-64
> >>> setenv           MPICH_DIR /opt/xt-mpt/1.5.49/mpich2-64/P2
> >>> setenv           MPICH_DIR_FTN_DEFAULT64
> >> /opt/xt-mpt/1.5.49/mpich2-64/P2W
> >>> prepend-path     LD_LIBRARY_PATH
> /opt/xt-mpt/1.5.49/mpich2-64/P2/lib
> >>> prepend-path     PATH /opt/xt-mpt/1.5.49/mpich2-64/P2/bin
> >>> prepend-path     MANPATH /opt/xt-mpt/1.5.49/mpich2-64/man
> >>> prepend-path     MANPATH /opt/xt-mpt/1.5.49/romio/man
> >>> prepend-path     PE_PRODUCT_LIST MPT
> >>> The debug library you want to use is thus going to be
> >> picked up by the
> >>> mpicc installed at:
> >>> /opt/xt-mpt/1.5.49/mpich2-64/P2DB
> >>> 2) Now with the cray compiler scripts like cc, ftn, etc.
> >> you specify the
> >>> alternate location to use for compiling/linking by
> >>> cc -driverpath=/opt/xt-mpt/1.5.49/mpich2-64/P2DB/bin -o
> >> a.out.debug ......
> >>> or whichever path is appropriate for the xt-mpt installed
> >> on your system.
> >>> 3) When you rerun the binary, you may want to set the MPICH_DBMASK
> >>> environment variable to 0x200.
> >>> I am pretty sure you are running out of memory, based on
> the area in
> >>> the ADIO_Calc_my_req where the error arises.  Clearly this
> >> is not a very
> >>> good way to report an oom condition.  I'll investigate.
> >>> You may be able to save some memory by tweaking the environment
> >>> variables controlling mpi buffer space.  Refer to the
> >> intro_mpi man page
> >>> on your xt/qk system.
> >>> Hope this helps,
> >>> Howard
> >>> Wei-keng Liao wrote:
> >>>> Well, I am aware of mpich2version, but unforturnately that
> >> command is not
> >>>> available to users on that machine. The only commands
> >> avaliable to me are
> >>>> mpicc, mpif77, mpif90, and mpicxx.
> >>>> Wei-keng
> >>>> On Fri, 25 May 2007, Anthony Chan wrote:
> >>>>> <mpich2-install-dir>/bin/mpich2version may show if
> >> --enable-g is set.
> >>>>> A.Chan
> >>>>> On Fri, 25 May 2007, Wei-keng Liao wrote:
> >>>>>> The problem is that I cannot run my own mpich on the
> >> machine. I can see
> >>>>>> the MPICH I am using is of version 2-1.0.2 from peeking
> >> at mpif90 script.
> >>>>>> Is there a way to know if it is built using
> >> --enable-g=dbg option from
> >>>>>> the
> >>>>>> mpif90 script?
> >>>>>> I don't know if this help, but below is the whole
> error message:
> >>>>>> aborting job:
> >>>>>> application called MPI_Abort(MPI_COMM_WORLD, 1) - process <id>
> >>>>>> (there are 4000 lines, each with a distinct id number)
> >>>>>> ----- DEBUG: PCB, CONTEXT, STACK TRACE ---------------------
> >>>>>> PROCESSOR [ 0]
> >>>>>> log_nid  =    15  phys_nid  = 0x98  host_id =   7691
> >> host_pid  = 18545
> >>>>>> group_id = 12003  num_procs = 4000  rank    =     15
> >> local_pid =    3
> >>>>>> base_node_index =    0   last_node_index = 1999
> >>>>>> text_base  = 0x00000000200000   text_len  = 0x00000000400000
> >>>>>> data_base  = 0x00000000600000   data_len  = 0x00000000a00000
> >>>>>> stack_base = 0x000000fec00000   stack_len = 0x00000001000000
> >>>>>> heap_base  = 0x00000001200000   heap_len  = 0x0000007b000000
> >>>>>> ss  = 0x000000000000001f  fs  = 000000000000000000  gs  =
> >>>>>> 0x0000000000000017
> >>>>>> rip = 0x00000000002d46fe
> >>>>>> rdi = 0x0000000006133a90  rsi = 0xffffffffdc0003c2  rbp =
> >>>>>> 0x00000000ffbf9d40
> >>>>>> rsp = 0x00000000ffbf9cc0  rbx = 0x0000000000000190  rdx =
> >>>>>> 0x000000003eb08c39
> >>>>>> rcx = 0x0000000008ea18b0  rax = 0x0000000008ecff30  cs  =
> >>>>>> 0x000000000000001f
> >>>>>> R8  = 0x0000000007ad2ab0  R9  = 0xfffffffffffffe0c  R10 =
> >>>>>> 0x0000000008e6bd30
> >>>>>> R11 = 0x0000000000000262  R12 = 0x0000000000000a8c  R13 =
> >>>>>> 0xfffffffff0538770
> >>>>>> R14 = 0x00000000fffffe0c  R15 = 0x0000000008ed3dc0
> >>>>>> rflg = 0x0000000000010206   prev_sp = 0x00000000ffbf9cc0
> >>>>>> error_code = 6
> >>>>>> SIGNAL #[11][Segmentation fault]  fault_address =
> >> 0xffffffff78ed4cc8
> >>>>>>   0xffbf9cc0  0x        ffbf9cf0 0x             fa0 0x
> >>     a00006b6c 0x
> >>>>>> a8c3e9ab7ff
> >>>>>>   0xffbf9ce0  0x         8ed7c50 0x             7d0 0x
> >>             0 0x
> >>>>>> 6b6c002d455b
> >>>>>>   0xffbf9d00  0x         8ea18b0 0x         8e6bd30 0x
> >>       61338a0 0x
> >>>>>> fa0
> >>>>>>   0xffbf9d20  0x               0 0x         61338a0 0x
> >>         8036c 0x
> >>>>>> 8ec4390
> >>>>>>   0xffbf9d40  0x        ffbf9e80 0x          2d2280 0x
> >>       8ecff30 0x
> >>>>>> 8036c
> >>>>>>   0xffbf9d60  0x             fa0 0x        ffbf9de4 0x
> >>      ffbf9de8 0x
> >>>>>> ffbf9df0
> >>>>>>   0xffbf9d80  0x        ffbf9df8 0x               0 0x
> >>             0 0x
> >>>>>> 8ebc680
> >>>>>>   0xffbf9da0  0x            1770 0x     7d000a39f88 0x
> >>             0 0x
> >>>>>> 650048174f
> >>>>>>   0xffbf9dc0  0x  14fb184c000829 0x         6a93500 0x
> >>      ffbf9e30 0x
> >>>>>> 292e54
> >>>>>>   0xffbf9de0  0x               0 0x         8ed3dc0 0x
> >>           7af 0x
> >>>>>> 0
> >>>>>>   0xffbf9e00  0x               0 0x         8ecc0a0 0x
> >>       8ecff30 0x
> >>>>>> 8036c
> >>>>>>   0xffbf9e20  0x       100000014 0x         8e6bd30 0x
> >>       8ea18b0 0x
> >>>>>> 1770
> >>>>>>   0xffbf9e40  0xffffffff6793163f 0x    6b6c00a39fa8 0x
> >>   fa00000000f 0x
> >>>>>> 61338a0
> >>>>>>   0xffbf9e60  0x        4c000829 0x          14fb18 0x
> >>            65 0x
> >>>>>> 0
> >>>>>>   0xffbf9e80  0x        ffbf9ee0 0x          2a397c 0x
> >>        866b60 0x
> >>>>>> ffbf9eb0
> >>>>>> Stack Trace:  ------------------------------
> >>>>>> #0  0x00000000002d46fe in ADIOI_Calc_my_req()
> >>>>>> #1  0x00000000002d2280 in ADIOI_GEN_WriteStridedColl()
> >>>>>> #2  0x00000000002a397c in MPIOI_File_write_all()
> >>>>>> #3  0x00000000002a3a4a in PMPI_File_write_all()
> >>>>>> #4  0x00000000002913a8 in pmpi_file_write_all_()
> >>>>>> could not find symbol for addr 0x73696e6966204f49
> >>>>>> On Fri, 25 May 2007, Robert Latham wrote:
> >>>>>>> On Fri, May 25, 2007 at 03:56:16PM -0500, Wei-keng Liao wrote:
> >>>>>>>> I have an MPI I/O application that runs fine up to
> >> 1000 processes, but
> >>>>>>>> failed when using 4000 processes. Parts of error message are
> >>>>>>>>     aborting job:
> >> process 1456
> >>>>>>>> My question is what debug flags should I use for
> >> compiling and running
> >>>>>>>> in
> >>>>>>>> order to help find what exact location in function
> >> ADIOI_Calc_my_req()
> >>>>>>>> causes this error?
> >>>>>>> Hi Wei-keng
> >>>>>>> If you build MPICH2 with --enable-g=dbg, then all of
> >> MPI will be built
> >>>>>>> with debugging symbols.   Be sure to 'make clean'
> >> first: the ROMIO
> >>>>>>> objects might not rebuild otherwise.
> >>>>>>> I wonder what caused the abort?  maybe ADIOI_Malloc
> >> failed to allocate
> >>>>>>> memory?  Well, a stack trace with debugging symbols should be
> >>>>>>> interesting.
> >>>>>>> ==rob
> >>>>>>> Rob Latham
> >>>>>>> Mathematics and Computer Science Division    A215 0178
> >> EA2D B059 8CDF
> >>>>>>> Argonne National Lab, IL USA                 B29D F333
> >> 664A 4280 315B
