[MPICH] debug flag
Wei-keng Liao
wkliao at ece.northwestern.edu
Fri May 25 17:18:42 CDT 2007
Well, I am aware of mpich2version, but unforturnately that command is not
available to users on that machine. The only commands avaliable to me are
mpicc, mpif77, mpif90, and mpicxx.
Wei-keng
On Fri, 25 May 2007, Anthony Chan wrote:
> <mpich2-install-dir>/bin/mpich2version may show if --enable-g is set.
> A.Chan
> On Fri, 25 May 2007, Wei-keng Liao wrote:
>> The problem is that I cannot run my own mpich on the machine. I can see
>> the MPICH I am using is of version 2-1.0.2 from peeking at mpif90 script.
>> Is there a way to know if it is built using --enable-g=dbg option from the
>> mpif90 script?
>> I don't know if this help, but below is the whole error message:
>> aborting job:
>> application called MPI_Abort(MPI_COMM_WORLD, 1) - process <id>
>> (there are 4000 lines, each with a distinct id number)
>> ----- DEBUG: PCB, CONTEXT, STACK TRACE ---------------------
>> PROCESSOR [ 0]
>> log_nid = 15 phys_nid = 0x98 host_id = 7691 host_pid = 18545
>> group_id = 12003 num_procs = 4000 rank = 15 local_pid = 3
>> base_node_index = 0 last_node_index = 1999
>> text_base = 0x00000000200000 text_len = 0x00000000400000
>> data_base = 0x00000000600000 data_len = 0x00000000a00000
>> stack_base = 0x000000fec00000 stack_len = 0x00000001000000
>> heap_base = 0x00000001200000 heap_len = 0x0000007b000000
>> ss = 0x000000000000001f fs = 000000000000000000 gs = 0x0000000000000017
>> rip = 0x00000000002d46fe
>> rdi = 0x0000000006133a90 rsi = 0xffffffffdc0003c2 rbp = 0x00000000ffbf9d40
>> rsp = 0x00000000ffbf9cc0 rbx = 0x0000000000000190 rdx = 0x000000003eb08c39
>> rcx = 0x0000000008ea18b0 rax = 0x0000000008ecff30 cs = 0x000000000000001f
>> R8 = 0x0000000007ad2ab0 R9 = 0xfffffffffffffe0c R10 = 0x0000000008e6bd30
>> R11 = 0x0000000000000262 R12 = 0x0000000000000a8c R13 = 0xfffffffff0538770
>> R14 = 0x00000000fffffe0c R15 = 0x0000000008ed3dc0
>> rflg = 0x0000000000010206 prev_sp = 0x00000000ffbf9cc0
>> error_code = 6
>> SIGNAL #[11][Segmentation fault] fault_address = 0xffffffff78ed4cc8
>> 0xffbf9cc0 0x ffbf9cf0 0x fa0 0x a00006b6c 0x a8c3e9ab7ff
>> 0xffbf9ce0 0x 8ed7c50 0x 7d0 0x 0 0x 6b6c002d455b
>> 0xffbf9d00 0x 8ea18b0 0x 8e6bd30 0x 61338a0 0x fa0
>> 0xffbf9d20 0x 0 0x 61338a0 0x 8036c 0x 8ec4390
>> 0xffbf9d40 0x ffbf9e80 0x 2d2280 0x 8ecff30 0x 8036c
>> 0xffbf9d60 0x fa0 0x ffbf9de4 0x ffbf9de8 0x ffbf9df0
>> 0xffbf9d80 0x ffbf9df8 0x 0 0x 0 0x 8ebc680
>> 0xffbf9da0 0x 1770 0x 7d000a39f88 0x 0 0x 650048174f
>> 0xffbf9dc0 0x 14fb184c000829 0x 6a93500 0x ffbf9e30 0x 292e54
>> 0xffbf9de0 0x 0 0x 8ed3dc0 0x 7af 0x 0
>> 0xffbf9e00 0x 0 0x 8ecc0a0 0x 8ecff30 0x 8036c
>> 0xffbf9e20 0x 100000014 0x 8e6bd30 0x 8ea18b0 0x 1770
>> 0xffbf9e40 0xffffffff6793163f 0x 6b6c00a39fa8 0x fa00000000f 0x 61338a0
>> 0xffbf9e60 0x 4c000829 0x 14fb18 0x 65 0x 0
>> 0xffbf9e80 0x ffbf9ee0 0x 2a397c 0x 866b60 0x ffbf9eb0
>> Stack Trace: ------------------------------
>> #0 0x00000000002d46fe in ADIOI_Calc_my_req()
>> #1 0x00000000002d2280 in ADIOI_GEN_WriteStridedColl()
>> #2 0x00000000002a397c in MPIOI_File_write_all()
>> #3 0x00000000002a3a4a in PMPI_File_write_all()
>> #4 0x00000000002913a8 in pmpi_file_write_all_()
>> could not find symbol for addr 0x73696e6966204f49
>> On Fri, 25 May 2007, Robert Latham wrote:
>>> On Fri, May 25, 2007 at 03:56:16PM -0500, Wei-keng Liao wrote:
>>>> I have an MPI I/O application that runs fine up to 1000 processes, but
>>>> failed when using 4000 processes. Parts of error message are
>>>> aborting job:
>>>> application called MPI_Abort(MPI_COMM_WORLD, 1) - process 1456
>>>> My question is what debug flags should I use for compiling and running in
>>>> order to help find what exact location in function ADIOI_Calc_my_req()
>>>> causes this error?
>>> Hi Wei-keng
>>> If you build MPICH2 with --enable-g=dbg, then all of MPI will be built
>>> with debugging symbols. Be sure to 'make clean' first: the ROMIO
>>> objects might not rebuild otherwise.
>>> I wonder what caused the abort? maybe ADIOI_Malloc failed to allocate
>>> memory? Well, a stack trace with debugging symbols should be
>>> interesting.
>>> ==rob
>>> Rob Latham
>>> Mathematics and Computer Science Division A215 0178 EA2D B059 8CDF
>>> Argonne National Lab, IL USA B29D F333 664A 4280 315B
