[MPICH] Using mpiexec with gdg
Anthony Chan
chan at mcs.anl.gov
Wed May 23 11:01:27 CDT 2007
On Tue, 22 May 2007, Christian Zemlin wrote:
> Dear MPICH experts,
> I am using MPICH2 on a Beowulf cluster, and I am trouble setting breakpoints.
> This is a typical interaction I have with gdb:
> testm at master:~/test> mpiexec -gdb -n 4 ./RNC
> 0-3: (gdb) break main
> 0-3: Note: breakpoint 1 also set at pc 0x402560.
> 0-3: Breakpoint 2 at 0x402560
> 0-3: (gdb) run
> 0-3: Continuing.
> 0:
> 0: Program received signal SIGSEGV, Segmentation fault.
> 0: 0x00002b49f7267ace in _int_free () from /lib64/libc.so.6
> 0: (gdb) 0: (gdb)
> The problem is that although I set the breakpoint, the program does not stop.
Did you recompile your program with -g ?
Any other option is to run your program with ddd, i.e.
mpiexec -n 4 ddd ./RNC
A.Chan
