[MPICH] ch3:sctp configure broken
Steve Kargl sgk at troutmask.apl.washington.edu
Tue May 22 17:31:29 CDT 2007
It appears that configuring the ch3:sctp device is broken
on FreeBSD.  With mpich2-1.0.5p4, I see
sourcing /usr/tmp/mpich2-1.0.5p4/src/mpid/ch3/setup_device
RUNNING SETUP_DEVICE FOR THE CH3 DEVICE
sourcing /usr/tmp/mpich2-1.0.5p4/src/mpid/ch3/channels/sctp/setup_channel
RUNNING SETUP_CHANNEL FOR THE SCTP CHANNEL
checking for sched_yield... no
checking for yield... no
checking for usleep... no
checking for sleep... no
checking for select... no
RUNNING CONFIGURE FOR CH3 DEVICE
checking for make... make
checking whether clock skew breaks make... no
checking whether make supports include... yes
checking whether make allows comments in actions... yes
checking for virtual path format... VPATH
checking whether make sets CFLAGS... yes
checking for gcc... gcc
checking for C compiler default output file name... configure: error: C compiler cannot create executables
See `config.log' for more details.
configure: error: Configure of src/mpid/ch3 failed!
Using nemesis seems to work except that it causes random nodes
in my cluster to reboot.
Steve
