[MPICH] SO_REUSEADDR seems not work in programs with MPI
    马章超
    mzcroy at gmail.com
    Thu May 17 00:30:19 CDT 2007
Greetings. In my mpi programs, some socket interface(tcp) is needed. As the
system`s archetecture is designed, I have to close server side first. Then
the error message "Bind: Address Already in Use" is always meet.  I find
that using the function setsockopt() to set SO_REUSEADDR parameter is the
only way to avoid this problem.  But with some experiments I find this way
can't work in MPI programs while work good in socket raw examples.  Is that
because MPI reset the socket option when MPI_Finalize is called?
Any suggestions will be greatly appreciated.
Best regards!
Roy Ma
 <mzcroy at gmail.com>
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20070517/0694c72a/attachment.htm>
