[MPICH] Re: [gt-user] Run a wrapped command with MPI
Matias Alberto Gavinowich
mattlistas at gmail.com
Tue May 15 15:51:03 CDT 2007
Hello:
Thank you all for your help. The problem was indeed the missing
command line arguments.
I patched mi pbs.pm script from the
$GLOBUS_LOCATION/lib/perl/Globus/GRAM/JobManager directory in the way
I describe below. It is a bit untidy, but I got it to work.
Replaced:
print CMD "#!/bin/sh\n";
print CMD 'cd ', $description->directory(), "\n";
print CMD "$rsh_env\n";
print CMD $description->executable(), " $args\n";
close(CMD);
chmod 0700, $cmd_script_name;
With:
if ($description->jobtype() eq "mpi")
if ($mpiexec ne 'no')
# below is the line as it originally was
else
# mpirun case
print CMD $description->executable(), " \"\$@\"\n";
else
close(CMD);
And replaced:
my $machinefilearg = "";
if ($cluster)
$machinefilearg = ' -machinefile $PBS_NODEFILE';
print JOB "$mpiexec $machinefilearg -n " .
$description->count();
else
print JOB "$mpirun -np " . $description->count();
if ($cluster)
print JOB ' -machinefile $PBS_NODEFILE';
print JOB " $cmd_script_name < " . $description->stdin() . "\n";
With:
if ($cluster)
# this line is copied from below, I separated the two
cases and only modified the mpirun case
else
if ($cluster)
print JOB " $cmd_script_name $args < " .
# I broke the following line into two cases above
# print JOB " $cmd_script_name < " . $description->stdin() . "\n";
Thanks again,
Matt
On 5/15/07, Brian R. Toonen <toonen at mcs.anl.gov> wrote:
> Some implementations of mpirun pass command line arguments to the executable
> which are then used during MPI_Init() to determine how many processes to
> start, etc. Your script isn't passing those command line arguments to the
> cpi executable.
> Try the following script. It's a bit ugly, but it should work.
> #!/bin/sh
> IFS=
> args=""
> while test $# -gt 0 ; do
> args="$args '"`echo "$1" | sed -e "s/'/'"'"'"'"'"'"'/g"`"'"
> shift
> done
> args=`echo "$args" | sed 's/^ *//'`
> eval ./cpi "$args"
> --brian
> |-----Original Message-----
> |From: owner-gt-user at globus.org [mailto:owner-gt-user at globus.org] On Behalf
> |Of Matias Alberto Gavinowich
> |Sent: Monday, May 14, 2007 14:43
> |To: mpich-discuss at mcs.anl.gov; torqueusers at supercluster.org; gt-
> |user at globus.org
> |Subject: [gt-user] Run a wrapped command with MPI
> |Hello:
> |I am having the following problem.
> |I can run a comand through mpi invoking:
> |mpirun -np 2 ./cpi (I am using my machines.LINUX default file).
> |Two processes are started, as expected.
> |Then, I write a wrapper script that looks like:
> |#!/bin/sh
> |./cpi (I also tried with a full path)
> |and I run:
> |mpirun -np 2 ./cpiwrapper
> |Only one process is started in this case.
> |The trick is I need it to work with a wrapper, because jobmanager-pbs
> |from globus invokes it this way (with a wrapper script).
> |AFAIK, I am running MPICH1.
> |Has anyone come accross this?
> |Thank you,
> |Matt
