[MPICH] Run a wrapped command with MPI
Ralph Butler
rbutler at mtsu.edu
Mon May 14 16:09:34 CDT 2007
Make sure you are using the new mpich2 which prefers usage of mpiexec
instead of mpirun.
I don't have process management systems, grids, etc. But, on a
fairly plain
vanilla linux cluster it works fine:
(bp400:65) % mpdtrace
bp400
bp401
(bp400:66) % cat tempsh
#!/bin/sh
/bin/hostname
(bp400:67) % mpiexec -l -n 2 tempsh
0: bp400
1: bp401
On MonMay 14, at Mon May 14 2:43PM, Matias Alberto Gavinowich wrote:
> Hello:
> I am having the following problem.
> I can run a comand through mpi invoking:
> mpirun -np 2 ./cpi (I am using my machines.LINUX default file).
> Two processes are started, as expected.
> Then, I write a wrapper script that looks like:
> #!/bin/sh
> ./cpi (I also tried with a full path)
> and I run:
> mpirun -np 2 ./cpiwrapper
> Only one process is started in this case.
> The trick is I need it to work with a wrapper, because jobmanager-pbs
> from globus invokes it this way (with a wrapper script).
> AFAIK, I am running MPICH1.
> Has anyone come accross this?
> Thank you,
> Matt
