[MPICH] Run a wrapped command with MPI
Matias Alberto Gavinowich
mattlistas at gmail.com
Mon May 14 14:43:24 CDT 2007
Hello:
I am having the following problem.
I can run a comand through mpi invoking:
mpirun -np 2 ./cpi (I am using my machines.LINUX default file).
Two processes are started, as expected.
Then, I write a wrapper script that looks like:
#!/bin/sh
./cpi (I also tried with a full path)
and I run:
mpirun -np 2 ./cpiwrapper
Only one process is started in this case.
The trick is I need it to work with a wrapper, because jobmanager-pbs
from globus invokes it this way (with a wrapper script).
AFAIK, I am running MPICH1.
Has anyone come accross this?
Thank you,
Matt
