[MPICH] Semaphores Discussion Forum
    William Gropp
    gropp at mcs.anl.gov
    Mon May  7 11:08:54 CDT 2007
Most Unix system calls will return this error.  Typically, you need
something like
do {
     err = systemcall(...);
} while (err == -1 && errno == EINTR);
There are times when you may want to do something else after a signal
handler operates, but this code is what is usually required.
Bill
On May 4, 2007, at 6:43 PM, Manal Helal wrote:
> Hi
> I know this is irrelevant to MPI, but I use besides MPI, threads
> and synchronize with semaphore and have an error "The call was
> interrupted by a signal handler." on a sem_wait
> Do you know a forum that I can discuss this problem with?
> I appreciate your help,
> Kind Regards,
> Manal
