[MPICH] ROMIO error
Yong Chen
chenyon1 at iit.edu
Fri May 4 16:34:32 CDT 2007
I got it, thanks!
Yong
Rajeev Thakur wrote:
> Yong,
> ROMIO is missing support for the MPI-2 function
> MPI_Type_create_resized. Until we fix it, you can use MPI_type_struct with
> an explicit MPI_LB and MPI_UB.
> Rajeev
>> -----Original Message-----
>> From: owner-mpich-discuss at mcs.anl.gov
>> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Yong Chen
>> Sent: Friday, May 04, 2007 3:24 PM
>> To: mpich-discuss at mcs.anl.gov
>> Subject: [MPICH] ROMIO error
>> Hi,
>> I kept getting the following error when I run the sample
>> MPI_File_set_view() code,
>> Error: Unsupported datatype passed to ADIOI_Count_contiguous_blocks
>> [cli_0]: aborting job:
>> application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0
>> rank 0 in job 125 x86_32838 caused collective abort of all ranks
>> exit status of rank 0: killed by signal 9
>> I did a debugging with gdb, the filetype caused the problem and
>> MPI_File_set_view() threw the error. Indeed, if filetype is replaced
>> with MPI_INT, it works well. Did a search on google, still
>> cannot figure
>> out why. Can anyone give me a clue? thanks very much! The
>> following is
>> the sample code.
>> #include "mpi.h"
>> int main( int argc, char *argv[] )
>> MPI_Aint lb, extent;
>> MPI_Datatype etype, filetype, contig;
>> MPI_Offset disp;
>> MPI_File fh;
>> int buf[1000];
>> MPI_Init( &argc, &argv );
>> /* ... other application code ... */
>> MPI_File_open(MPI_COMM_WORLD, "datafile",
>> MPI_MODE_CREATE | MPI_MODE_RDWR,
>> MPI_INFO_NULL, &fh);
>> MPI_Type_contiguous(2, MPI_INT, &contig);
>> lb = 0;
>> extent = 6 * sizeof(int);
>> MPI_Type_create_resized(contig, lb, extent, &filetype);
>> MPI_Type_commit(&filetype);
>> disp = 5 * sizeof(int); /* assume displacement in
>> this file view
>> is of size equal to 5 integers */
>> etype = MPI_INT;
>> /* filetype = MPI_INT; */
>> MPI_File_set_view(fh, disp, etype, filetype, "native",
>> MPI_INFO_NULL);
>> MPI_File_write(fh, buf, 1000, MPI_INT, MPI_STATUS_IGNORE);
>> MPI_Finalize();
>> return 0;
>> Thanks,
>> Yong
