[MPICH] MPI-IO, vector dataype
    Rajeev Thakur
    thakur at mcs.anl.gov
    Thu May  3 13:24:58 CDT 2007
Can you write it to a local Unix file system instead of PVFS and see if it
works there?
Rajeev
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Russell
> L. Carter
> Sent: Thursday, May 03, 2007 1:04 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [MPICH] MPI-IO, vector dataype
> Ok,
> Made the change, same output.  Looking at the written file with od -i,
> and inserting blank lines at block boundaries:
> rcarter at feyerabend [344] od -i testfile
> 0000000           0           1           2           3
> 0000020           4           5           6           7
> 0000040           0           2           4           6
> 0000060           8          10          12          14
> 0000100          16          18          20          22
> 0000120          24          26          28          30
> 0000140          32          34          36          38
> 0000160          40          42          44          46
> 0000200          48          50          52          54
> 0000220          56          58          60          62
> 0000240
> Given (just the relevant code snippets)
>     nprocs = 2, FILESIZE = 256,  INTS_PER_BLK = 4,
>     bufsize(FILESIZE/nprocs), nints(bufsize/sizeof(int)),
>    filetype.Create_vector(nints/INTS_PER_BLK, INTS_PER_BLK,
>                           INTS_PER_BLK * nprocs);
>    which works out to  Create_vector(4, 8, 16)  (intrinsic
> type MPI_INT)
>    f.Set_view(INTS_PER_BLK*sizeof(int)*myrank, MPI_INT,
>                     filetype, "native", MPI_INFO_NULL);
>    which works out to Set_view(32 or 0 bytes, ...)
>    f.Write(obuf, nints, MPI_INT, status);
> Then shouldn't the number pointed to at 0000100 be 8, not 16?
> It should be the first int of the second block of rank 0's data.
> Each proc is writing out ints (myrank + 1)*i, so
> rank 0's are sequential and rank 1's are even only.
> Russell
> Rajeev Thakur wrote:
> > The write and read should use nints as the count instead of
> bufsize. (I
> > don't know if that alone will solve the problem.)
> > Rajeev
> >> L. Carter
> >> Sent: Wednesday, May 02, 2007 5:21 PM
> >> Subject: [MPICH] MPI-IO, vector dataype
> >> Hi folks,
> >> I'm having some cognition problems understanding
> >> how vector datatype works with readall/writeall.
> >> (I.e, I'm likely being stupid).  At any rate,
> >> I've appended a short program derived from
> >> the UsingMPI2/moreio/read_all.c example that
> >> generates the following output.  I expected
> >> that there would be no lines output beginning
> >> with 'myrank, i, obuf[i]...'.  Any clues on
> >> where I'm being clueless?
> >> Many thanks,
> >> Russell
> >>   mpiexec -n 2 /home/rcarter/mpibin/rwall
> >> Starting rwall.
> >> Starting rwall.
> >> process 0 wrote 128process  ints1
> >>   wrote 128 ints
> >> process process 1 read 0128 read  ints128
> >>   ints
> >> myrank, i, obuf[i], ibuf[i]: 0 8 8 0
> >> myrank, i, obuf[i], ibuf[i]: 0 9 9 2
> >> myrank, i, obuf[i], ibuf[i]: 0 10 10 4
> >> myrank, i, obuf[i], ibuf[i]: 0 11 11 6
> >> myrank, i, obuf[i], ibuf[i]: 0 12 12 8
> >> myrank, i, obuf[i], ibuf[i]: 0 13 13 10
> >> myrank, i, obuf[i], ibuf[i]: 0 14 14 12
> >> myrank, i, obuf[i], ibuf[i]: 0 15 15 14
> >> myrank, i, obuf[i], ibuf[i]: 0 17 17 18
> >> myrank, i, obuf[i], ibuf[i]: 0 18 18 20
> >> myrank, i, obuf[i], ibuf[i]: 0 19 19 22
> >> myrank, i, obuf[i], ibuf[i]: 0 20 20 24
> >> myrank, i, obuf[i], ibuf[i]: 0 21 21 26
> >> myrank, i, obuf[i], ibuf[i]: 0 22 22 28
> >> myrank, i, obuf[i], ibuf[i]: 0 23 23 30
> >> myrank, i, obuf[i], ibuf[i]: 0 24 24 32
> >> myrank, i, obuf[i], ibuf[i]: 0 25 25 34
> >> myrank, i, obuf[i], ibuf[i]: 0 26 26 36
> >> myrank, i, obuf[i], ibuf[i]: 0 27 27 38
> >> myrank, i, obuf[i], ibuf[i]: 0 28 28 40
> >> myrank, i, obuf[i], ibuf[i]: 0 29 29 42
> >> myrank, i, obuf[i], ibuf[i]: 0 30 30 44
> >> myrank, i, obuf[i], ibuf[i]: 0 31 31 46
> >> rwall end.
> >> rwall end.
> >> Here's the program:
> >> #include "mpi.h"
> >> #include <iostream>
> >> using namespace std;
> >> struct tester
> >>      tester()
> >>          : myrank(MPI::COMM_WORLD.Get_rank()),
> >>            nprocs(MPI::COMM_WORLD.Get_size()),
> >>            filetype(MPI::INT),
> >>            fname("pvfs2:/mnt/pvfs/tst/testfile")
> >>          std::ios::sync_with_stdio(false);
> >>          filetype.Commit();
> >>          obuf = new int[bufsize];
> >>          ibuf = new int[bufsize];
> >>      ~tester()
> >>          delete[] obuf;
> >>          delete[] ibuf;
> >>      void write()
> >>          for (int i = 0; i < nints; ++i) {
> >>              obuf[i] = (myrank + 1) * i;
> >>          MPI::File f = MPI::File::Open(MPI::COMM_WORLD,
> fname.c_str(),
> >>                                        MPI_MODE_CREATE |
> >> MPI_MODE_WRONLY,
> >>                                        MPI::INFO_NULL);
> >>          f.Write(obuf, bufsize, MPI_INT, status);
> >>          cerr << "process " << myrank << " wrote "
> >>               << status.Get_count(MPI_INT) << " ints" << endl;
> >>          f.Close();
> >>      void read()
> fname.c_str(),
> >>                                        MPI_MODE_RDONLY,
> >> MPI::INFO_NULL);
> >>          f.Read(ibuf, bufsize, MPI_INT, status);
> >>          f.Close();
> >>          cerr << "process " << myrank << " read "
> >>              if (obuf[i] != ibuf[i]) {
> >>                  cerr << "myrank, i, obuf[i], ibuf[i]: " <<
> >> myrank << " "
> >>                       << i << " " << obuf[i] << " " <<
> >> ibuf[i] << endl;
> >> private:
> >>      static const int FILESIZE = 256,  INTS_PER_BLK = 8;
> >>      int myrank, nprocs, bufsize, nints, *obuf, *ibuf;
> >>      MPI::Datatype filetype;
> >>      string fname;
> >>      MPI::Status status;
> >> int main()
> >>      cerr << "Starting rwall.\n";
> >>      try {
> >>          MPI::Init();
> >>          tester t;
> >>          t.write();
> >>          t.read();
> >>          MPI::Finalize();
> >>      } catch (exception &e) {
> >>          cerr << "\nCaught exception: " << e.what() << endl;
> >>          return -1;
> >>      } catch (MPI::Exception& e) {
> >>          cerr << "\nError:\n" << e.Get_error_string();
> >>          return -2;
> >>      cerr << "rwall end.\n";
> >>      return 0;
> Russell L. Carter
> Esturion, LLC
> 2285 Sandia Drive
> Prescott, Arizona 86301
> rcarter at esturion.net
> 928 308-4154
