[MPICH] error in MPI_Waitall
    Rajeev Thakur
    thakur at mcs.anl.gov
    Mon Mar 26 11:16:46 CDT 2007
Signal 11 means there was a segmentation fault; that is, the program
accessed a memory location that it was not assigned. It is most likely a bug
in your code.
Rajeev
  _____
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Jeffrey Stephen
Sent: Sunday, March 25, 2007 6:05 PM
Subject: [MPICH] error in MPI_Waitall
I am trying to run an MPICH2 application over 2 processors on a dual
processor x64 Linux box (SuSE 10). I am getting the following error message:
Fatal error in MPI_Waitall: Other MPI error, error stack:
MPI_Waitall(242)..........................: MPI_Waitall(count=2,
req_array=0x5bbda70, status_array=0x7fff461d9ce0) failed
MPIDI_CH3_Progress_wait(212)..............: an error occurred while handling
an event returned by MPIDU_Sock_Wait()
MPIDI_CH3I_Progress_handle_sock_event(413):
MPIDU_Socki_handle_read(633)..............: connection failure
(set=0,sock=1,errno=104:Connection reset by peer)
rank 0 in job 2  Demeter_18432   caused collective abort of all ranks
  exit status of rank 0: killed by signal 11
The "cpi" example that comes with MPICH2 executes correctly. I am using
MPICH2-1.0.5p2 which I compiled from source.
Does anyone know what the problem is?
cheers
steve
Climate change will impact on everyone.
Natural Resources Conference 2007
Climate Change - Queensland takes action
Wednesday 23 May 2007
Brisbane Convention and Exhibition Centre
Register your interest in attending - visit
www.nrw.qld.gov.au/events/nrconference
The information in this email together with any attachments is
intended only for the person or entity to which it is addressed
and may contain confidential and/or privileged material.
Any form of review, disclosure, modification, distribution
and/or publication of this email message is prohibited, unless
as a necessary part of Departmental business.
If you have received this message in error, you are asked to
inform the sender as quickly as possible and delete this message
and any copies of this message from your computer and/or your
computer system network.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20070326/90174dec/attachment.htm>
