[MPICH] MPI_REDUCE with MPI_IN_PLACE fails with memory error
Anthony Chan
chan at mcs.anl.gov
Tue Mar 13 13:06:26 CDT 2007
Hi Martin,
Ignore my message on MPI_IN_PLACE. Rajeev is right. My suggested usage
of MPI_IN_PLACE is actually wrong. Sorry for the confusion.
A.Chan
On Tue, 13 Mar 2007, Rajeev Thakur wrote:
> In my opinion, there is no problem with the use of MPI_IN_PLACE on non-root
> nodes in the example below, because the recvbuf argument is not significant
> on non-root nodes. You can pass NULL or any garbage or even MPI_IN_PLACE
> there.
> Rajeev
> > -----Original Message-----
> > From: owner-mpich-discuss at mcs.anl.gov
> > [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Anthony Chan
> > Sent: Tuesday, March 13, 2007 12:15 PM
> > To: Rusty Lusk
> > Cc: Martin Kleinschmidt; mpich-discuss at mcs.anl.gov
> > Subject: Re: [MPICH] MPI_REDUCE with MPI_IN_PLACE fails with
> > memory error
> > The error checking profiling library should be able to detect
> > the problem.
> > A.Chan
> > On Tue, 13 Mar 2007, Rusty Lusk wrote:
> > > I believe our error-checking profiling library detects this error,
> > > doesn't it?
> > > On Mar 13, 2007, at 11:08 AM, Anthony Chan wrote:
> > > > We have no access to intel 9.x compilers yet, can't
> > directly verify
> > > > the
> > > > reported problem. However you may be using MPI_IN_PLACE
> > incorrectly
> > > > in non-root process.
> > > > On Tue, 13 Mar 2007, Martin Kleinschmidt wrote:
> > > >> The corresponding lines of code are:
> > > >> #ifdef PARALLEL
> > > >> if (myid .eq. 0) then
> > > >> call MPI_Reduce(MPI_IN_PLACE, vecf2(1),
> > > >> $ n*nneue,
> > > >> $ MPI_double_precision, MPI_SUM, 0,
> > > >> $ MPI_Comm_World, MPIerr)
> > > >> else
> > > >> call MPI_Reduce(vecf2(1),MPI_IN_PLACE,
> > > >> $ n*nneue,
> > > >> endif
> > > >> #endif
> > > > Try calling MPI_Reduce with MPI_IN_PLACE in send buffer in all
> > > > ranks, i.e.
> > > > $ n*nneue,
> > > > $ MPI_DOUBLE_PRECISION, MPI_SUM, 0,
> > > > $ MPI_COMM_WORLD, MPIerr)
> > > > A.Chan
> > > >> with n*nneue = 76160987, and 76160987*8 = 609287896, about 600 MB
> > > >> The point is: I thought, I could avoid the need for allocationg
> > > >> additional memory by using MPI_IN_PLACE, which obviously does not
> > > >> work.
> > > >> - do I use MPI_IN_PLACE in the right way?
> > > >> - why does MPI_IN_PLACE need additional memory?
> > > >> - is it possible to rewrite this code in a way that
> > eliminates the
> > > >> need
> > > >> for allocating additional memory? This part of the code is not
> > > >> time-critical - it is executed once every few hours.
> > > >> (I'm using mpich2-1.0.5p2, Intel fortran compiler
> > 9.1.040, Intel C
> > > >> compiler 9.1.045 for compiling both mpich and my code)
> > > >> ...martin
