[MPICH] MPI_REDUCE with MPI_IN_PLACE fails with memory error
Rusty Lusk
lusk at mcs.anl.gov
Tue Mar 13 12:04:41 CDT 2007
I believe our error-checking profiling library detects this error,
doesn't it?
On Mar 13, 2007, at 11:08 AM, Anthony Chan wrote:
> We have no access to intel 9.x compilers yet, can't directly verify
> the
> reported problem. However you may be using MPI_IN_PLACE incorrectly
> in non-root process.
> On Tue, 13 Mar 2007, Martin Kleinschmidt wrote:
>> The corresponding lines of code are:
>> #ifdef PARALLEL
>> if (myid .eq. 0) then
>> call MPI_Reduce(MPI_IN_PLACE, vecf2(1),
>> $ n*nneue,
>> $ MPI_double_precision, MPI_SUM, 0,
>> $ MPI_Comm_World, MPIerr)
>> else
>> call MPI_Reduce(vecf2(1),MPI_IN_PLACE,
>> $ n*nneue,
>> endif
>> #endif
> Try calling MPI_Reduce with MPI_IN_PLACE in send buffer in all
> ranks, i.e.
> $ n*nneue,
> $ MPI_DOUBLE_PRECISION, MPI_SUM, 0,
> $ MPI_COMM_WORLD, MPIerr)
> A.Chan
>> with n*nneue = 76160987, and 76160987*8 = 609287896, about 600 MB
>> The point is: I thought, I could avoid the need for allocationg
>> additional memory by using MPI_IN_PLACE, which obviously does not
>> work.
>> - do I use MPI_IN_PLACE in the right way?
>> - why does MPI_IN_PLACE need additional memory?
>> - is it possible to rewrite this code in a way that eliminates the
>> need
>> for allocating additional memory? This part of the code is not
>> time-critical - it is executed once every few hours.
>> (I'm using mpich2-1.0.5p2, Intel fortran compiler 9.1.040, Intel C
>> compiler 9.1.045 for compiling both mpich and my code)
>> ...martin
