[MPICH] problems with MPICH2 on a 64 bit platform
    William Gropp
    gropp at mcs.anl.gov
    Mon Jul 30 17:46:51 CDT 2007
Hi Paula,
In the first case, the default name of the MPI library for MPICH2 is
libmpich.a , so you'll need -lmpich instead of -lmpi .  We did this
to avoid conflicts with vendor-supplied libmpi.a , but if you don't
have a vendor-supplied mpi library, you can change the name that
MPICH2 uses for the library (I believe with the environment variable
MPILIBNAME).
In case 2, MPICH2 has been configured to support threads
(MPI_THREAD_MULTIPLE), and it is using routines from the pthread
library to ensure that the threads do not interfere with each other.
You can either configure MPICH2 with --enable-threads=funneled or add
-lpthreads to the link line
Bill
On Jul 30, 2007, at 5:30 PM, Paula González wrote:
> Hello!
> My name is Paula González and I'm working on a 64 bit platform,
> under Ubuntu Feisty Fawn. I compiled MPICH2 using 64-bit  Intel
> ifort but I believe I got it wrong, since I'm getting different
> error messages.
> 1 case:
> ifort time_manager.o spherical_fourier.o mpp_data.o
> shallow_diagnostics.o atmos_model.o mpp_io.o atmosphere.o fms_io.o
> tracer_manager.o diag_util.o spectral_damping.o fft.o
> shallow_physics.o memuse.o memutils.o threadloc.o diag_data.o
> diag_axis.o get_cal_time.o diag_manager.o transforms.o spherical.o
> constants.o fms.o mpp_pset.o spec_mpp.o grid_fourier.o
> field_manager.o diag_output.o gauss_and_legendre.o nsclock.o
> leapfrog.o mpp_parameter.o platform.o fv_advection.o mpp.o fft99.o
> mpp_domains.o shallow_dynamics.o -o fms.x -L/usr/local/lib -lnetcdf
> -lmpi -lsma
> ld: cannot find -lmpi
> another case:
> /usr/local/lib/libmpich.a(allreduce.o ): In function
> `MPIR_Allreduce_inter':
> allreduce.c:(.text+0x1ce): undefined reference to
> `pthread_getspecific'
> allreduce.c:(.text+0x1fe): undefined reference to
> `pthread_setspecific'
> /usr/local/lib/libmpich.a( allreduce.o): In function `MPIR_Allreduce':
> allreduce.c:(.text+0x54c): undefined reference to
> allreduce.c:(.text+0x57c): undefined reference to
> and so on.
> Could these be related to the fact that I did not onfigure my
> MPICH2 correctly? Can you Help me ?
> Thanks!!!
> Paula González
> << we are drowning, the small ones, with loose lips and lies ... >>
