[MPICH] running an MPI prog
Mark.Donohue at avtechgroup.com
Fri Jul 27 11:02:04 CDT 2007
Hey Anthony. Thanks for the reply. Yeah this seems to run ok. Here's
what I get (I only had three machines in the ring at that time). Is
this what you would expect to see?
Aero1% mpiexec -n 3 cpi
Process 0 of 1 on Aero2
pi is approximately 3.1415926544231341, Error is 0.0000000008333410
wall clock time = 0.000453
Process 0 of 1 on Aero1
wall clock time = 0.000622
Process 0 of 1 on Aero3
wall clock time = 0.000455
-----Original Message-----
Sent: Thursday, July 26, 2007 6:29 PM
To: Mark Donohue
Cc: mpich-discuss at mcs.anl.gov
Subject: Re: [MPICH] running an MPI prog
Can you run a simple MPI program like cpi in <mpich2-build-dir>/examples
cd <mpich2-build-dir>/examples
<mpich2-build-dir>/bin/mpiexec -n 4 cpi
A.Chan
On Thu, 26 Jul 2007 Mark.Donohue at avtechgroup.com wrote:
> Hi yall. Please help a simpleton with some basic MPICH knowledge. I
> am trying to run an MPI version of a CFD program that I use regularly.
> I installed MPICH2 on our Linux cluster, but when I try and run, I get
> the error at the bottom. I split my computational domain into two
> partitions, and the program complains that the number of partitions
> (2) doesn't equal the number of processors. Huh? Is there a way to
> fix this? I realize that this error is coming from my MPI code and
> not from MPICH itself, but I was hoping to gain some insight into why
> this is happening. For some reason I thought specifying "-n 2" meant
> that it will begin running with two processors. All the documentation
> I've found hasn't been able to answer this for me. Thanks a bunch!
> -Mark
> Aero1% mpiexec -l -machinefile myhosts -n 2 usm3d_52p.mpip4
> Baseline_Elev
> 0: ** WARNING: fp stack is not empty
> 0: ** after call to etime in routine usm52p
> 0:
> 0: ** popping the fp stack and continuing...
> 1: ** WARNING: fp stack is not empty
> 1: ** after call to etime in routine usm52p
> 1:
> 1: ** popping the fp stack and continuing...
> 1: FORTRAN STOP
> 1: the MPI has been initialized on 1 processors
> 1: no. of partitions != no. of processors
> 0: FORTRAN STOP
> 0: the MPI has been initialized on 1 processors
> 0: no. of partitions != no. of processors
