[MPICH] Problems with mpicc
Jeffrey B. Layton
laytonjb at charter.net
Thu Jul 19 16:12:54 CDT 2007
I can't even seem to compile to create test. I just tried a
different binary output name with the same result
(it hung for about 5 minutes).
Jeff
> Just in case this might be the problem, I'll remind you that there is
> a system program named "test" which does nothing but set the exit code.
> Are you sure you aren't accidentally running this program instead of
> the one compiled from code.c but linked as "test"?
> Rusty
> On Jul 19, 2007, at 3:47 PM, Jeffrey B. Layton wrote:
>> Afternoon,
>> I built mpich2-1.0.5p4 with g95 and gcc 3.4.3 (see below).
>> Here's the configuration I used:
>> ./configure -prefix=/home/laytonj/bin/mpich2-1.0.5p4-g95 \
>> --enable-f77 --enable-f90 --enable-romio --disable-mpe \
>> --with-file-system="nfs+ufs"
>> MPICH2 seemed to build and install just fine. Then I tried
>> compiling one of the non-MPI-IO codes from the MPI-2
>> book (see below). When I compile:
>> mpicc code.c -o test
>> it just hangs for a long time (I've let it sit for over 20 mins.).
>> The load stays around 1.0 and the memory usage doesn't
>> increase during the whole time.
>> I know this one is a toughy. Any ideas?
>> Thanks!
>> Jeff
>> gcc configuration:
>> % gcc -v
>> Reading specs from /usr/lib/gcc/i386-redhat-linux/3.4.3/specs
>> Configured with: ../configure --prefix=/usr --mandir=/usr/share/man
>> --infodir=/usr/share/info --enable-shared --enable-threads=posix
>> --disable-checking --with-system-zlib --enable-__cxa_atexit
>> --disable-libunwind-exceptions --enable-java-awt=gtk
>> --host=i386-redhat-linux
>> Thread model: posix
>> gcc version 3.4.3 20050227 (Red Hat 3.4.3-22.1)
>> sample code:
>> /* example of sequential Unix write into a common file */
>> #include "mpi.h"
>> #include <stdio.h>
>> #define BUFSIZE 100
>> int main(int argc, char *argv[])
>> int i, myrank, numprocs, buf[BUFSIZE];
>> MPI_Status status;
>> FILE *myfile;
>> MPI_Init(&argc, &argv);
>> MPI_Comm_rank(MPI_COMM_WORLD, &myrank);
>> MPI_Comm_size(MPI_COMM_WORLD, &numprocs);
>> for (i=0; i<BUFSIZE; i++)
>> buf[i] = myrank * BUFSIZE + i;
>> if (myrank != 0)
>> MPI_Send(buf, BUFSIZE, MPI_INT, 0, 99, MPI_COMM_WORLD);
>> else {
>> myfile = fopen("testfile", "w");
>> fwrite(buf, sizeof(int), BUFSIZE, myfile);
>> for (i=1; i<numprocs; i++) {
>> MPI_Recv(buf, BUFSIZE, MPI_INT, i, 99, MPI_COMM_WORLD,
>> &status);
>> fclose(myfile);
>> MPI_Finalize();
>> return 0;
